This post is here to help answer some basic questions, address some basic needs of the DRZ. It is not intended to be overly specific, or all in compassing. If you need more info on anything you read here, search in the forum first, or failing that, post a question...
If your new to this forum.. and wish to start a new thread
Use this button.
:thinking:1: What is it I've heard about the motor side cases being thin and fragile on the DRZ?
A: The side case covers on the DRZ are made from thin magnesium and prone to damage in a fall. You can easily protect them with an add on cover. One such cover is made for Thumper Talk, available from the Thumper Talk store It is applied with silicone adhesive, but any of the automotive silicone gasket makers will work just fine. The permitex Ultra series, in black is a favored choice.
2: I heard something about the shifter needing a modification?
A: From the factory, the back side of the shifter has a sharp edge to the casting. If left as is, it can and will puncture the side case in a fall. The shifter should be removed and have those sharp edges rounded over to prevent this.
:thinking:2.1: I am having trouble getting a good shift from 1st to 2nd, 3nd to 3rd, and back, Is there something easy I can do to fix this??
A: A simple fix that often works is to remove the shifter, and move it one spline up or down to suite your riding position. Another issue newer riders have is being too timid when shifting.. It’s not a kick, but not a gentle lift either. You need to shift with some authority. The DRZ transmission shares its lube with the motor, so what you feed it, feeds the trans. Most rides can feel a difference in better shifting when using a quality synthetic oil.. With out getting in a what oil is better discussion.. Simply try it for shifting feel.. If you think it shifts better, then use it for that reason it self, if no other.
Additionally there are longer shifters if your feet and extra long, as in the size 13 range. White Brothers sells one, and it can be found in the TT store
3: When in gear,, my bike will only start with the clutch in.. What’s up with that?
A: This would be the clutch interlock switch.. Many, chose to disable this,, so the bike may be started at any time.. Additionally, this switch has been know to fail in mild falls, involving the left hand controls.. leaving the rider unable to start the bike at all. If you do this mod,, the rider must remember the bike will start in gear.. and caution should be used at all times.
:thinking:4: This is my first water cooled bike,, should I be concerned with damage to the radiators?
A: Yes, most all riders would agree, the rads of a water cooled bike should be protected. There are several aftermarket rad guards for the DRZ, some fit only the E model, some only the S model. Unabiker Racing makes a guard for both. And is highly recommended by most, if not all in this forum that use them.
5: I have a DRZ E model bought in CA... Is it different then other states E models?
A: Yes,, in 2004 the CA E models received some parts from the S motor, and some CA E model specific parts.. We believe this is for emission reasons,, and only applicable to CA delivered bikes. Cams, base gasket and carb are the items different. That we know about at this time
In 2007 All DRZ E's received an EPA neutering. The BSR36 CV carb being the worst of it. The Line between E and S models became even thiner.
:thinking:6: My CA DRZ has a black box back by the fender,, what is it? OR My CA bike seems to run out of gas but the tank is full.. this started happening after a fall... What is wrong?
A: CA S & SM models have a fuel tank evaporation system installed. The idea is it captures fuel vapors for m the tank, and stores them in the charcoal canister. till they can be purged back into the intake. The problem is,, raw fuel gets in the canister, from over filling the tank, or in a fall.. once this happens and the charcoal gets saturated with fuel, it no longer allows the tank to vent.. and your bike stops running. Many, remove this system on their OFF ROAD only bikes.
7: I have DRZ what carb do I have?
A: Up until 2003 all E models have the Keihin FCR 39mm flat slide carb, 2004 and later CA E models have the Mikuni BSR36 CV carb, just like the S, and all E models after 2006 have the BSR
ALL DRZ S & SM models have the Mikuni BSR36 CV carb
8: What jets, and jetting kits do I need for my carb?
A: The BSR36 is best re-jetted with the Kit from James Dean or DynaJet. The Dj kit comes in two flavors, one for the S/E, one for the SM. Either can be made to work. Search the
jetting forum
The FCR39 works really well with the James Dean kit and uses the long hex for the main
:thinking:9: I want to add a kick starter to my DRZ S, but the parts guy said it will only fit the DRZ E.. Is that true?
A: The Kick Starter kit fits ALL model DRZ's. new and old, E, K or S or SM.[/B][/U] [/COLOR] There will be some left over parts when installing on the S & SM, as the included manual decompression assembly will not fit the those heads.
10: Why does my DRZ die or lose power when I am going over jumps or after lofting the front wheel over an obstacle
A. The DRZ has a kick stand kill switch Over rough terrain, jumps and such, the kick stand can come down slightly,, the kill switch activates, and the motor will die or hesitate. Both very bad things while trying to balance on two wheels. Most disable the switch, and never miss it. Just remember to put the kick stand up before riding off.
:thinking:11: So, I got a screaming deal on a Yoshimura exhaust pipe for an E model will an E exhaust system fit my S?
A: Yes,, The E pipe will fit the S, except for the mid pipe mount. If doing away with the rear pegs, most find then can use the lower peg mounting hole to fit the mid pipe mount to. Due to differences in bikes, trail damage, and pipes,, some have found these two point would not line up, and had to make a bracket for this to work. It is not recommended to run with out the mid pipe mount in place.
:thinking: 12: What fixes for known issues should I look at doing to my new (new to me) DRZ?
A: Some of the common issues or potential issues with the DRZ are
1: Regulator wiring harness plug corroding or melting (see Charging system diagnoses Plus the "Free Power MOD" ) in this forum)
2: Loose primary gear nut. (For now, look in the common stuff thread in this forum. I’ll put an article together for this fix later)
3: Loose Counter Shaft gear nut (see Counter Shaft Sprocket "Loctite Fix" in this forum)
4: Loose counter balancer gear nut. Search Loctite fix in this forum.
5: Jetting of the stock BSR or FCR carb.. Bottom line, from the factory it's set to pass an emission standard.. period. All stock DRZ's (ALL Bikes really)benefit from jetting to your local area. This can be done with OEM jets.. or you can get a jetting kit from James Dean or Dyno Jet. With this you get a different needle, a set of jets, and the support needed to help you dial it in. (search the jetting forum, FCR in the DRZ forum and 3x3 mod in the DRZ forum)
6: Fragile case covers (case savers from TT or another supplier and a good skid plate are a smart investment,, see this FAQ for more info.. Search DRZ forum for "cracked cover" if you want to read about the folks who did not install a simple case saver)
6: Little to no grease in the steering head and swing arm / suspension links. . The deal is, Suzuki uses a very thin amount of Vaseline like grease in both the steering head bearings and the rear suspension and swing arm bearings. This grease is often found gone, or contaminated to the point of complete part failure. Add in the fact that there are parts like the swing arm bolt, that are not greased at all, but still subject to corrosion if not cleaned and protected (water proof grease or anti seize) makes for a good reason in itself to take the rear suspension off once a year, clean inspect grease. Trying to get a stuck awing arm bolt out is not a lot of fun. The DRZ E has a grease fitting on the swing arm, and it will lube the two bearings in that one part. But that fitting does nothing for the bolt, or all the other moving parts in the rear suspension. Many DRZ owners have gone to fix a tight, binding or loose steering stem, only to find the OEM bearings rusted to junk. Few minutes to clean, inspect and grease will go a long way to keeping the DRZ going.
8: Starter clutch to flywheel bolts come loose and shear. Yes, this has happend on more then a few DRZ's See Stator and Starter clutch LocTite fix in this Tech forum for full details
:thinking: 13: What is this I hear about issues with the Auto Cam chain tensioner?
A: The Auto Cam Chain Tensioner (ACCT) has had some failure issues over the different model years.. The current version (2003 and later model years) has not seen as many failures. But still puts too much constant pressure on the chain, causing excessive wear. With the history, and continued issues of previous and current designs.. Many replace the ACCT of all years with a Manual Cam Chain Tensioner (MCCT). There are two choices as of this writing... One is the MCCT from APE. It was the first one on the market and has been is used with good success. The APE design works, but has never been updated. The other choice, and the newer design is made and sold by our very own TT shop..... Thumper Talk MCCT This design not only looks better, it has additional sealing features the APR does not. The TT MCCT has taken the best designs features of MCCT's that came before it, combined them in to one great design.
Installing the MCCT is simple, instructions come with the part, and can be found by searching the DRZ forum,, or asking one of the hundreds of members who have installed one.
[BREAK=Continuation of DRZ Basic FAQ]
:thinking:14: How do I change my oil?
A: To drain the oil on a DRZ,, you have to remove two plugs,, One on the bottom of the motor, and 1 in the frame.. Located on the lower part of the front down tube. Just below the oil hose, which we will discuss in a minute.
Warm up your motor for a few minutes,, then remove both drain plugs. Next remove the oil filter cover. There are two o rings under that cover,, 1 that seals the cover it self,, and a smaller one,, behind the filter. This one seals the filter to the motor,, and is often lost with the oil, or oil filter. Without this o-ring,, you may have dirty oil bypassing your filter.
Another issue that has been blamed for case damage is the crush sealing washer on the case drain plug. It can after use form a wedge, which can easily damage or destroy the case. It’s not really an issue of cost, but availability. Chances are good your Suzuki or Kawasaki dealer will not stock them,, But for a mere $1.80 and 7-10 working day wait they can get it for you. :bonk: Me? I’m a spares nut.. I stock spares for all likely repairs and maintenance on all 7 bikes in my garage. So my suggestion is, use one of the online parts suppliers, and order a dozen crush washers… put then in your tool box and always have a spare ready.. If you run out, you can reuse an old washer, with care and after inspection. Many have used then 10’s of times, some only a few times and cracked the case. Just too many variables to say for sure how many times they can be reused. Consider them a consumable part and replace.
Lastly,, we have the oil line screen.. Many do not even know it is there.( the screen is Part number 49065).
This screen should be cleaned as a first time oil change, any time after internal motor work has been done,, and once a season,, just to be sure.
:thinking:15: My counter shaft sprocket nut is loose (or I'm changing the sprocket) What should I do?
See the white page write up "Counter Shaft Sprocket "Loctite Fix" in the main FAQ forum
:thinking:16: I found "cracks" inside the oil filter cavity when I did my first oil change.. HELP>>>>>?
A: RELAX.... they are just casting marks... You will find them in the oil filter sump and just about any inside, non finished part of the case. They hurt nothing,,, and are just part of the casting process. :thumbsup: Some times they will look like cracks, sometimes raised. You may also see these casting marks on the cases. Some of the sides case or coves are worse then others.
:thinking:17: Can I hook up Heated grips, a GPS or other electrical device to the DRZ power system??
A: Yes, but only to a point. The DRZ E, S and SM all have a 200 watt stator. The system can easily handle some additionally load. But 200 watts goes fast. Couple your additional accessories that max out or come close to stator wattage, then have some repeated start and stops, where the battery can not recover from that last start before you have to start it again. And you will quickly exceed the battery storage capacity.
Powering your GPS or other small device can easily be done by hooking up the leads (through a fuse) directly to the battery.
:thinking:18: Battery not charging, smell of melted insulation, left leg is on fire, all of these are signs of a faulty connection between the stator/ rectifier and battery system. The white two wife plug found behind the left frame cover is not the best. They have been an issue for all year DRZ’s. The plug can be snapped together incompletely, I can easily become corroded or otherwise damaged. When these things happen the plug terminals arc, or otherwise have a high resistance, which melts the plug, only further causing an issue, till you have no connectivity and no charge to the battery. .?
A: See the White Page write up Charging system diagnoses and the Free Power MOD in the main FAQ forum.
The post will be locked, and placed in the FAQ forum. If you think you have a basic piece of info that would benefit a new DRZ rider. PM me with it, and if appropriate for this post I'll add it. Think basic,, " I wish I new that" type things,, keep it short,, no part number, direction, just simple general info. The reader can search or ask for more in depth answers as there time and desire allows.
