'06 YZ450 Hot Start Question
7 replies to this topic
  • angrybob
Posted March 30, 2008 - 01:51 PM
When I pulled my carb apart to send it to ZipTy for the carb mod kit, there was no spring above the hot start plunger. The shop manual was inconclusive so I assembled the carb without. I went for my second ride on this bike and the hot start felt not right.
My buddy rides a CRF450 and his hot start lever has a positive return...probably a spring. Mine feels like a wet noodle.
I look at the online fiche and it shows a spring. TT does not have a carb schematic for the '06 carb. Using powersportspro.com, its part # 37. Not much help I know...
Can anyone confirm that there is in fact a spring above the hot start. I think there should be.
Thanks.
  • William1
Posted March 30, 2008 - 04:34 PM
Yes, there is supposed to be a spring between the plunger and the hot start nut.
  • crayztwentyseven
Posted March 30, 2008 - 06:52 PM
yes mine has a spring, put a spring in and the hot start will no longer leak air and run like piss
  • angrybob
Posted March 30, 2008 - 08:23 PM
Thought so. Thanks fellas.
  • yz450vet
Posted May 11, 2008 - 05:50 AM
Guys
I have a 03 Y50F and I recently replaced the hotstart cable as the old one was stiff. The new cable is equally as stiff and I am trying to figure out how to adjust it properly with proper recoil etc. There is a spring between the plunger and the nut. I did notice a fair amount of dirt around the plunger. Any other ideas?
  • angrybob
Posted May 11, 2008 - 05:58 AM
Mine is an '06 and I have no idea if they are different, but the spec for an '06 is 3-6mm of lever play.
  • Ga426owner
Posted May 11, 2008 - 07:41 AM
Guys
yep the dirt will build up as long as you have a plastic nut that holds it all together in the carb. Replace with a Alum nut Turner, Zipty etc...then this stays clean. Clean it/the hole and add a tiny dab of grease to the sides of the plunger..then adjust cable - good to go:thumbsup:
  • yz450vet
Posted May 14, 2008 - 07:54 AM
Thanks
I just ordered a Zip Ty hot start carb nut and when it comes I follow your advice.
  • Hot  50 replies
  • On January 15, 2017
  • 3 replies
  • Hot  113 replies
  • Hot  47 replies
