XR650L Oil Capacity Poll
99 replies to this topic
Poll: XR650L Oil Capacity (148 member(s) have cast votes)
XR650L Oil Capacity
  1. 2 qts. (23 votes [15.54%])
    Percentage of vote: 15.54%
  2. Voted 2.06 qts. (42 votes [28.38%])
    Percentage of vote: 28.38%
  3. Voted 2 1/4 qts. (25 votes [16.89%])
    Percentage of vote: 16.89%
  4. Voted 2 1/2 qts. (29 votes [19.59%])
    Percentage of vote: 19.59%
  5. Voted 2 3/4 qts. (17 votes [11.49%])
    Percentage of vote: 11.49%
  6. Voted 3 qts. or more (12 votes [8.11%])
    Percentage of vote: 8.11%
Vote Guests cannot vote
  • XR650L_Dave
Posted April 03, 2008 - 08:24 AM
#41
Only one problem with that. ^^^^^^ With 2 3/4 quarts in my bike, the crank case level is PERFECT. If I take the inspection bolt out while it's on the sidestand, no oil comes out. It's not until I get the bike perfectly upright that any oil at all comes out the hole. I don't proclaim to have the answer as to why there seems to be no unanimity on this, but I still have to stick to my story which is 2 3/4 quarts = Just below the top level of crosshatch on the dipstick and perfect crankcase level.:prof: :bonk:
You pulled that check plug with the engine running?
Dave
  • Bibleman
Posted April 03, 2008 - 12:33 PM
#42
No, was I supposed to?
  • XR650L_Dave
Posted April 03, 2008 - 01:09 PM
#43
Terchnically, the engine sump level check plug only gives a meaningful reading with the engine running.
The top of the correct sump level is right at the bottom of the hole.
Right after the engine is shut off it'd still be 'good' but would start to leak as oil leaked down into the sump.
Dave
  • Bibleman
Posted April 03, 2008 - 04:08 PM
#44
Hmmm, just checked the owners manual and it says to check the crankcase level before starting the engine (pg 88).
  • XR650L_Dave
Posted April 04, 2008 - 08:03 AM
#45
Are we both talking about the sump check-plug?
Dave
  • Kenzo
Posted April 04, 2008 - 12:08 PM
#46
Dave
the Clymer Manual states to check the crankcase oil level with the engine shut off and "let the oil settle"...
the Honda Shop Manual does not say but they're both in agreement that the proper level is the bottom of the crankcase bolt hole threads...
as a side note i do not see any appreciable difference in level from oil draining back into the case...mine seems to hold it's frame/tank level...maybe i better check the screen next change :prof:
:bonk:
  • XR650L_Dave
Posted April 04, 2008 - 02:32 PM
#47
I thought my shop manual explained how to check it running- I'll have to look.
Dave
  • jetfuel
Posted April 04, 2008 - 03:28 PM
#48
Alright guys... From the "Honda Service Manual"
  • Bibleman
Posted April 04, 2008 - 04:15 PM
#49
Well, well, well. No wonder we can't figure this thing out. The service manual is different from the owners manual (at least the one that came with my '07) which says on p.88 regarding the crankcase inspection bolt....."If the crankcase oil level is low, add the recommended engine oil BEFORE STARTING THE ENGINE (emphasis mine) to check the engine oil level.'
  • jetfuel
Posted April 04, 2008 - 05:02 PM
#50
Yes that would certainly be confusing.
It had seemed something was slightly off between your two descriptions.
Thats why I figured I'd post that up...:prof:
Now fill'em up and..:bonk:
  • Huffa 2
Posted April 04, 2008 - 07:24 PM
#51
:prof: So it appears that even HONDA is confused on this issue! :bonk:
  • Purcell69
Posted April 04, 2008 - 11:06 PM
#52
I know the whole capacity is a very heated topic. After reading the last few posts, and having completed my first oil change for the XRL at home, I learned two important things...I over-filled mine by almost a full quart. Running at highway speed I was getting a significant amount of oil residue in the airbox and occasional misfires.
I had been checking the oil as per the direction of the service advisor (run 5 minutes at idle, shut off and stand 5 minutes, then check with bike vertical.) Every time it came up short I ended up adding about 4 ounces to get the level close to the upper mark. The end result was excess oil in the system.
I also learned that it is not possible to add the recommended quantity of oil all at one time. I made a big mess on the frame and floor when I reached about 1.8 quarts.
After getting the oil to the correct 2.06 qts. the bike runs down the highway smoothly with no misses or hesitations. When I checked my oil immediately after riding, as suggested by Martinfan, my oil level was between the two "p's" in the word "Upper" on the dipstick.
For those who do choose to run 2 3/4-3 qts. you may be having better luck than I was due to lower engine speeds or a different crank case vent system. Mine is desmogged and currently vented to the airbox. I am very comfortable running 2.06 qts . now.
-Joe
  • Bibleman
Posted April 05, 2008 - 04:26 AM
#53
I think that's great that you have come to a conclusion you're comfortable with Purcell, and I truly mean that. However, once again we have a part of the puzzle that doesn't fit. The owners manual says to "start the engine and let it idle for 3-5 minutes. After 2-3 minutes"....then check the level.
I think the poll shows that this is one of those topics we're all going to have to agree to disagree on. Fortunately, from everything I've read on this great forum, I don't think anyone has definitively damaged their engine from running anywhere between 2-3 quarts.
By the way, I certainly don't want to beat this topic to death, but I'm wondering if it's possible that there's any way on some bikes the engine oil is getting into one or both of the lower frame tubes, thereby creating a larger oil tank. Your thoughts???
  • HeadTrauma
Posted April 05, 2008 - 11:23 AM
#54
My 600 takes a little more than 2.06 quarts, but still less than 2.25, so I just voted for 2.06. I ride the bike around on easy mode for about 10min and then check the oil. I usually wait for the oil reservoir to start warming up. At an oil change, I fill the reservoir almost up to the top, do the ride around, and then check and add oil to the full mark. This method has proven to be repeatable for me and the amount of oil is very close to the factory spec, so I'm content with that.
Are some of you seriously stuffing close to three quarts in there?! That would be like overfilling my car by a quart and a half. :thumbsup:
  • zipper600
Posted April 06, 2008 - 05:54 AM
#55
94 XR600R. i always check oil immediatly after a ride.at middle of the dipstick is good for me.
always put 2.5 liters (dont ask me how many quarts is it.dont give a ****)with filter change included. Always good. No seal blowing or whatever and even with the frame filter in this condition it "only" seized a rocker arm.
  • Bibleman
Posted April 06, 2008 - 08:58 AM
#56
:thumbsup: Wow, just curious how long it was since it was previously cleaned. When I checked mine at 1k miles there was only two tiny dots of something stuck on it.
  • zipper600
Posted April 06, 2008 - 11:29 AM
#57
in my oppinion no one ever cleaned it..i had a big "TIC TIC" on valves so i openned head and found a seized rocker arm..i checked all lines and filters and found this frame filter in this condition... this proves the XR reliability..the engine was starving in oil..
  • XR_Aaron
Posted April 07, 2008 - 12:39 PM
#58
-Joe
Mine also overflowed after about a litre and a half. I have just under two litres (2.11 quarts) of repsol synthetic and mine and it seems fine. I'm still worried about running less than most of you guys, but I check the level after every quick ride and it reads between the middle and full.
  • martinfan30
Posted April 20, 2008 - 11:08 AM
#59
There still seems to be some questions on this subject, so I re-stuck it.
Rich
  • frog13
Posted April 20, 2008 - 06:25 PM
#60
2.06 QUARTS (U.S.) = 2 U.S. quarts and 1.92 additional U.S. OUNCES.
Also, there is an additional check bolt on the right side of the head that you do check while the engine is running----regarding the case bolt:Whomever posted the copy of the manual, I believe it was talking about letting the engine get to a normal idiling state so the oil levels would stabilize----then shut it down/ keep it vertical and remove the bolt?.:thumbsup:
  • 4 replies
  • Hot  35 replies
  • 3 replies
Honda XR650L 2016
  • 0 reviews
  • 17 replies
