subframe
19 replies to this topic
  • lou_cano
Posted March 29, 2008 - 07:51 AM
My 2006 450 needs a new subframe. What years will fit on that years modle? I found a 2008 250f on ebay and I'm not sure it will fit on my bike. Please help
  • wheeldude
Posted March 29, 2008 - 11:34 AM
The part numbers are different for 06, 07 and 08 thru Yamaha. Check with AC and see if they make an aftermarket subframe. WD
  • Erick584
Posted March 29, 2008 - 12:55 PM
My experience with an AC subframe resulted in the mid-pipe bracket cracked, a small cross brace on the upper front broke out, and a cracked weld. I'd try and stick with OEM if I were you.
-erick
  • lou_cano
Posted March 29, 2008 - 04:17 PM
What web site should I look at buying it from?
  • kxman
Posted March 29, 2008 - 04:20 PM
Sorry I can't tell you what years will fit on your bike. I can offer this advice. Do not ever buy a sub-frame from AC Racing. Just as well take the money out of your pocket and set it on fire. Their stuff just doesn't fit. Been that way for years.
  • lou_cano
Posted March 29, 2008 - 04:39 PM
OK other than AC where else can I get an aftermarket subframe. oem subframe is $300
  • Dirtbiker05
Posted March 30, 2008 - 07:51 AM
the cheapest i could find for your bike is $240. dont know of any aftermarket...only oem.
  • lou_cano
Posted March 30, 2008 - 09:03 AM
Thanks for the info.
  • rickallen124
Posted March 30, 2008 - 02:41 PM
Lou I sent you a pm, did you get it?
  • rmzRacer293
Posted March 30, 2008 - 07:58 PM
lou cano im in the same situation as you right now. my 06 also needs a new subframe. have you found anything worth looking at yet? :prof:
  • Erick584
Posted March 31, 2008 - 05:52 PM
If i was you I'd check ebay and see what you can find for used oem subframes. I picked mine up last fall for $50. Good luck
  • rmzRacer293
Posted March 31, 2008 - 06:04 PM
I been looking on Ebay for the last couple days and I couldnt wait around any longer, so about a half hour ago I got a new OEM subframe for $217 shipped! Best deal I could find. It was from my local dealer tho so they hooked me up.
  • lou_cano
Posted April 01, 2008 - 05:38 PM
Yes. Thanks alot. But I am broke, so I dicided to fix it myself. I cut the subframe in three pices, strightened it out and I am going to weld it back together. I will post some pics when I am finished.
  • nap__kxf
Posted April 01, 2008 - 06:33 PM
hell i would have done that in the first place, if its already broken then your only options are to buy a new one or fix it, not like you need to worry about ruining it since it didn't work. :prof:
  • todds924
Posted April 02, 2008 - 04:13 PM
-erick
My experience with AC subframes are they SUCK! Garbage! And not alot cheaper than stock.
  • todds924
Posted April 02, 2008 - 04:15 PM
The part numbers ARE different but 06 to 08 will all interchange. I think the 07 is the cheapest priced though.
Posted April 02, 2008 - 06:47 PM
My experience with AC subframes are they SUCK! Garbage! ...
Just say what you think, OK? I hate it when you equivocate.
  • todds924
Posted April 03, 2008 - 07:36 PM
That is what i think.........And thats putting it mildly.
Posted April 03, 2008 - 08:03 PM
Alright, but don't be so wishy-washy next time. :prof:
  • todds924
Posted April 04, 2008 - 03:27 PM
Alright, but don't be so wishy-washy next time. :bonk:
:prof:
