07 YZ450F suspension
8 replies to this topic
  • Jonny Quest
Posted March 29, 2008 - 01:37 AM
I've decided on an 07 YZ450F (used), suspension-wise is stock going to be ok or will i need stiffer springs?
I'm 195 (dry-NO CLOTHES:eek: ), average C rider, strictly motocross.
Currently i have an 07 KTM 450sxf, with .48 springs by Factory Connection, and it's perfect... For that bike :prof:
Just not sure how much work or $$ i'll have to put into the YZF's stock suspension
  • Chevelle70SS
Posted March 29, 2008 - 03:59 AM
I would sugggest setting the sag and ride. Your wieght is about right for the stock spring rates. KTM makes a real nice bike but when it comes to suspension they are a little behind in that department. Yamaha stock stuff is really good, it might suprise you. Get use to what it has and judge from there. You can check spring rates for your weight vs stock at Racetech.com.
  • wheeldude
Posted March 29, 2008 - 11:38 AM
I weigh in at 225 and ride an 07 YZ450F. The stock suspension was soft for me, but not to the point of being unridable. That said, the spring rates should be pretty close for your weight and ability. WD
  • Jonny Quest
Posted March 29, 2008 - 12:04 PM
Really, all i'm concerned with is bottoming. A few G-outs really weakend my ankles, and with my skill level i'll sometimes case a jump, come up short on a bigger table-top, or slightly over shoot one.
My KTM has .48 springs in now, and it's pretty good. What's stock in the 07 YZF?
  • wheeldude
Posted March 29, 2008 - 02:04 PM
I believe .47's are stock on the 07. We went to .48's front and a 5.6 rear with complete Pro Action valving. What a difference.!!!!!WD
  • Family Man
Posted March 29, 2008 - 02:27 PM
I put a 5.8 Factory connection on the rear with the stock clicker settings and left the fork springs alone but set the compression clickers at 6 clicks from all the way in. I used to bottom the stock rear spring all the time, this setup feels great for me. Im about 195-205 lbs.
  • Slinkyman16
Posted March 29, 2008 - 04:15 PM
this is what enzo reccomended for me. .48 in the front stock in the rear.. with a revalve. i weigh around 205. c rider..
by the way i still have not sent my stuff off yet as im not sold that i need a revlave.. i love the way my stock stuff feels.. two clicks up front.. stock settings for the rear and im happy.. not bottoming out except on the big stuff.
  • mx614
Posted March 29, 2008 - 05:21 PM
I have a 2007 yz450 and I'm 6'4" 200lbs B rider and its way way way too soft from the factory. Needed 2 steps stiffer on forks and all the way to 5.9 on the rear,now I can actually go past half throttle. Its revalved from race tech and much better now. Stock feels more like an enduro feel or a womens setup. Doug dubach says its actually set up for a 165lb novice rider from the factory. Hope this helps
  • mikedabike
Posted March 29, 2008 - 06:56 PM
I would try it out with the stock stuff, it is really nice. The stock springrate is ballpark for you depending on how aggressive you are. I had an 04 with stiffer springs with valving done and the 07 is still way better even with the stock springs and I weigh 235 wihout gear.
  • Hot  36 replies
  • 0 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • Hot  491 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
