Guidance rebuilding the XR650R top-end, please...
30 replies to this topic
  • zimak
Posted March 28, 2008 - 10:47 AM
#21
And when your riding in the sand look up the painty hose trick to keep it extra clean in there.
Dont forget that cam chain.
  • scalejockey
Posted March 28, 2008 - 02:48 PM
#22
Hello,
I've been lurking here for some time, and am using my 1st post because need some guidance with my XR650R...
I purchased it 3 months ago (it's an '01), knowing the compression was a little 'soft'. I'd planned to rebuild it next winter, but after a trip to the dunes, some sand made it past my filter and apparently went through the cylinder... because now it's burning a considerable amount of oil (like a quart in 125 miles of street/trail riding), and the compression is ka-poot.
So... because I'm quite sure I sucked sand through it, I'd like to bore it out and have a new piston in it.
I went to the Honda shop this afternoon, and they were adamant that the XR650R cylinder cannot be bored.
So... that leaves me with 2 questions:
1.) Why not?
2.) What are riders doing then they're moving up to a larger piston? New sleeve?
I’ll likely stay with the 10:1 compression because I’ve read that the 11:1 requires machining to fit correctly? (Is this accurate?), but I’ll move to the stage 1 hot cams.
Please forgive me if I've posted this in the wrong forum, or if there's already a great thread on this subject (please direct me to it)~ I did several searches and couldn't find the answer...
Ryan
PM me when you get it done,maybe we can hook up out in the owhees and compare power.(Iv'e been needing a "reason" to make mine faster)..yes i'm married,I always need a reason.
  • RyanWilliamCantrell
Posted March 28, 2008 - 03:23 PM
#23
Sounds great. :bonk:
I ride the Kuna desert right now, since most of the Owyhee's are closed to motorized travel.
You should check out these guys, too:
motoidaho.com
:prof:
  • scalejockey
Posted March 28, 2008 - 06:33 PM
#24
motoidaho.com
:prof:
Cool!
  • Thumpmeister
Posted March 28, 2008 - 11:12 PM
#25
Ruin a boring bar???
Yeah, a boring bar is what is used to bore a standard non-plated cylinder. I guess I see what your saying; it wouldn't ruin the boring bar, but rather the cutter tip on the end of the bar.
  • BWB63
Posted March 30, 2008 - 07:13 PM
#26
I have the steel sleeve and would [COLOR="Red"]NOT[/COLOR] do that again. I would have the stock cylinder bored and re-Nikasiled. Millenium Technologies does great work as does Lukes Racing.
With a Nikasil cylinder you can run less the .0025" of piston to cylinder clearance but, with a steel sleeve you have to run at least .004" and you lose power, and the chance of a cold seize ( Barnum cold seize mine after the rebiuld) is not cool. Mike Powell's bike is Nikasil 680cc and you can tell it is much, much better.
Posted March 31, 2008 - 10:09 AM
#27
Compression is 80psi ~ ouch.
I'll start ordering parts this evening. :prof:
Thanks for all the input!
  • zimak
Posted April 02, 2008 - 12:27 PM
#28
Was that with the decomp pulled or without?
Page 8-4 Service manual
87psi (decompressor applied)
160psi (decompressor not applied)
If thats with the decomp pulled your perfect.
If not...she's cashed.
Posted April 02, 2008 - 03:41 PM
#29
Decomp out ~ which means she's 1/2 of what it's suppose to be.
  • zimak
Posted April 03, 2008 - 06:56 AM
#30
Ouch...wow that is really bad.
Even when I had 25% leak down through my rings I still could get 110-120psi with decomp out.
That is one seriously sick motor.
  • BWB63
Posted April 03, 2008 - 02:25 PM
#31
Some cam timing web pages for the XR650R:
http://www.scott-wor...engineering.htm
