Mounting Cycra handguards Front brake problems
4 replies to this topic
  • Cracker_Box
Posted March 26, 2008 - 02:01 PM
Since the brake line/banjo fitting is at the bottom of the master cylinder I was wondering what you guys have done to make your handguards fit?
I know that someone ele has had to have the same problem. I do not feel like running my lever pointing at the sky or the ground.
Any tips?
  • Evad101
Posted March 26, 2008 - 02:12 PM
You can grind off the nub that holds the line in 1 position, rotate the line so it clears giving you more room.
I added bar risers so it was not an issue with mine.
FYI, mine are triple clamp mounts.
  • erickdj
Posted March 26, 2008 - 02:13 PM
Any tips?
I have those handguards on my 07 wr. You might have to loosen up the banjo bolt a little bit to adjust the angle, in the end you might have to make some kind of compromise on the angle of the brake/handguard. I'm assuming you have the bar mounts, someone with triple clamp mounts might have something different to suggest.
  • race32
Posted March 26, 2008 - 02:15 PM
I've done mine 2 differnt ways. 1) turn the brake line over at the M/C to make it point out of the M/C the other way and 2) take it out of the 2 guides at the M/C and and put it on the top guide.
  • KennyMc
Posted March 26, 2008 - 02:20 PM
I went with the side triple clamp mount. You still need to a bit of grinding to get them to fit. The end result is no interferance whatsoever. You are free to have the levers at any angle.
The do also have a U handle bar mount. I haven't heard how much more freedom they offer offer.
http://www.thumperta...ad.php?t=515502
