400 piston on a 426 rod?
Will a 400 top end work on a 426 bottom with 426 rod? The circlip came off of the oil pump drive gear while WFO allowing it to make contact with brads on the back of the clutch basket, causing it to become a UFO and cracking the case where its shaft used to be. May have found a 426 bottom end and was wondering if it would work as I have maybe 6hrs on a fresh topend.
And yes, naturaly all of this happened about 18 miles from the truck.
Thanks for any help
CJ
Thanks for any help
CJ
No. The 426 con-rod small end is bigger (than the 400) to accomodate the larger 426 piston pin (19 mm IIRC). The 400 piston has a smaller (17 mm or 18 mm - can't remember) pin.
