Any tricks for getting airboot on carb 08YZ450f?
26 replies to this topic
  • wolfie12
Posted March 23, 2008 - 07:18 PM
Is it my imagination or is the subframe reassembly a real bear on this 08 YZ450f? I'm no rookie either, but there's gotta be a better way to get this boot seated on the carb. :confused: Its a super tight fit, and clearance if minimal by the shock. I'm just wondering if there any tricks or shortcuts.
Posted March 23, 2008 - 07:29 PM
The only trick I know is a shot of carb cleaner for lube, use a wire hook to work the boot on, and be patient.
  • thumpyz
Posted March 23, 2008 - 08:31 PM
Loosen the intake manifold boot, this will allow you to manipulate the carb into the air boot. once in, tighten airboot clamp and then manipulate the carb into the manifold boot. this is what i do, it might not work for you.:confused:
  • Family Man
Posted March 23, 2008 - 08:44 PM
Another vote for carb cleaner. Dries quick.
  • Kasjok
Posted March 23, 2008 - 11:20 PM
Get the subframe totally loose by removing all 3 bolts. Then remove the upper bolt of the shock and now you should get it there with no problemos. Loosening the carb from the front helps too. I have even installed the boot side first an then the front side.
  • mxracer206
Posted March 24, 2008 - 04:19 AM
I always remove the air box from the sub frame, it is just 4 bolts. It is easy to slide the air boot on then and the sub slides right back thru the air box.
  • Wiz636
Posted March 24, 2008 - 08:28 AM
That's the way I do it...loosen the clamp on the engine side of the carb and pull the back of the carb just slightly to left (not enough to come out of the forward boot). This gives just enough clearance from the shock for it to slide right on. No muss, no fuss. :excuseme:
  • nickeenoo
Posted March 24, 2008 - 02:24 PM
Is there any problem with using some kind of lube other than carb cleaner? Just wondering if you could use grease or something?
Nate
  • todds924
Posted March 24, 2008 - 02:31 PM
Nate
I know this sounds kinda dumb but it works. Make sure you have the clamp bolt all the way loose...I mean down to the last thread. Use a little contact cleaner or carb cleaner on the boot and try and slip the inside of the boot on the carb first <the shock side> When its done correctly the whole subframe and airbox will hang from the back of the carb. It is kinda tricky the first couple of times but after that its easy.
Posted March 24, 2008 - 04:16 PM
Nate
Yes, there is something wrong with that: It encourages the boot to slip back off sometime later.
Carb cleaner makes the rubber boot quite slippery, but then evaporates (even out from under the clamped boot), leaving the rubber surface clean, so that it can maintain a good seal. Oily things like grease, vaseline, WD-40, etc., stay oily too long.
  • nickeenoo
Posted March 24, 2008 - 04:30 PM
Thanks, I'm just about to tear the bike apart to lube it up, etc. and I'll make sure I have some carb cleaner on hand.
Nate
  • Ga426owner
Posted March 25, 2008 - 05:22 AM
There are several ways to do this - I have tried all of these. The bottomline......the boot is a PITA to get on period. Loosening the front boot and installing the rear is preferable. But the key here is patience and lots of it. I do not use any solvents just wrist strength.....get use to tearing up knuckles and yelling....but patience will win and it will go on. Try not to bend the boot clamp....it will not seal correctly once it is tweaked. :confused:
  • wolfie12
Posted March 25, 2008 - 03:14 PM
I think that pretty much covers how I did it the first time, haha...lotsa swearing, skinned knuckles, grunting and straightening out the clamp three or four times. This is the second time I pulled the subframe, and was hoping for a few tips that might help. Thanks everyone for all the replies and tips.:excuseme:
  • wolfie12
Posted March 25, 2008 - 06:09 PM
BEST TIP OF THE THREAD. Thanks! I did that tonight and it worked like a charm, no elbow grease required, the boot slid right on, without having to pull the carb out of the manifold. The subframe just goes on right over it and bolts right up. Great tip, I'd never done it like that on any bike, always reinstalled (and swore alot) the airbox and subframe as one piece. Should be a pinned FAQ imo.
  • dbyamaha
Posted January 09, 2010 - 08:48 PM
spit on it!!!
  • davbrucas
Posted January 09, 2010 - 08:59 PM
Easiest way is to just take the shock completely off...
  • FinchFan194
Posted January 09, 2010 - 09:15 PM
This is what I do, works like a charm:thumbsup:
  • motoscotty
Posted January 10, 2010 - 10:46 AM
This sounds funny but I heat the boot with a hair dryer and always goes right on.
I had problems in the past and got that tip from a guy at Yamaha.
S
  • MX4Life
Posted January 10, 2010 - 12:47 PM
You're not gonna believe it, but this was the driving force behind me getting a 2010. I fought with the subframe/airbox boot for 1/2 hour, only to find I had the clamp on backwards.:moon:
I ordered a 2010 the next day.
  • SAthump
Posted January 10, 2010 - 09:11 PM
I have found removing the upper shock bolt gives plenty on room the put the boot on the carb.
  • Hot  94 replies
  • Hot  36 replies
  • 0 replies
