My version of XR650R sidepanel vent.
27 replies to this topic
  • coreygauthier
Posted March 31, 2008 - 02:19 AM
#21
If you dont feel like spending hours doing yours check out the Xrsonly one
here it is on my bike...
http://www.facebook....29&id=566015104
I used a die grinder with a metal cut off disk and then a carbide bit. it doesn't have to be extemely precise because the trim plate covers the edge.
I'm running an high flow backfire screen as well
http://www.facebook....cb&id=566015104
I'm debating if i should run one size larger main for this mod....i ahve a 175 now and the bike is only uncorked.
  • hondacrf150f1
Posted March 31, 2008 - 03:07 AM
#22
The objective of my homemade venting job was to get even more airflow than XR's only. But due to that i need even more jetting modification, i know a couple guys that race that might be able to help me out with jetting, because i dont no where to start. (needle, pilot, main?:prof: )
I tried adjusting the idle mixture, that helped but didnt do nearly enough, i tried going form a 175 to a 178 main, that made it worse:foul:
maby i need a 70 Pilot instead of 68S:confused:
  • Frank ZX
Posted March 31, 2008 - 06:37 AM
#23
It would probably help to lower the clip a groove on the needle.That would be the first thing I would do.
  • Greco
Posted April 16, 2008 - 10:20 AM
#24
Ok fellas, back to the performance question.
Those of you that have had both the intact panel and the one "opened up", did you notice enough gains in horsepower to make it worth the trouble? After re jetting of course. With that much open space on the panel, I can see the filter getting dirty enough quickly enough to adversely affect performance in a dusty environment. If ya hafta tape over the holes every now and again, it kinda defeats the purpose, doesn't it?
Also, there is no way I would want to wash the bike without taping over the holes first. What say you, oh grand poobahs of the BRP?
  • coreygauthier
Posted April 17, 2008 - 02:18 AM
#25
I definetly think the screen kit is worth the time and the money. As for how much power it buys you....only a dyno will tell you that...I do beleive it's noticeable though.
I have the screen kit installed on my bike and i don't cover the screens while washing the bike. I just avoid directly spraying the area. Water that drips down on to them drains out the bottom of the cover anyway. If you were to drill many large holes in the sidecover....and not screen them off....the bike could suck in "cats,dogs, and small children" As for your filter getting dirty more quickly....yes it will.....more flow means more cleaning....
  • BWB63
Posted April 17, 2008 - 12:52 PM
#26
It is enough to make at least half a jet size larger and maybe a clip down on the needle. More fuel, more air......more power. It seems only to be up in the 6000+ rpm range. You've got to be really flying to notice power in that RPM range.
  • 96lt4c4
Posted April 18, 2008 - 07:07 AM
#27
I remember when I pulled the air box cover off my 01 WR 250F. I couldn't believe how crappy it ran. Defiantly need to go up a size or to on the main jet.
  • Greco
Posted April 18, 2008 - 09:58 AM
#28
Thanks for the info guys.
I found what I was looking for at www.borynack.com/xr650r
He has dyno charts and everything. The info I got was that the gains to be had from this mod are mainly up top. Down low or trail rides don't get the full compliment of the panel being open. Mine is dual sported and spends a lot of time on fire roads and jeep trails. I'm going to give it a shot. I'll keep one panel intact and buy another to modify in case it gets muddy or wet. I figure I can use the intact panel for washing as well.
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • Hot  186 replies
  • 22 replies
  • Hot  60 replies
  • 4 replies
