WHICH pink wire?
1 reply to this topic
  • oceanjake
Posted March 22, 2008 - 09:41 AM
My new WR stator has two pink wires. A light pink an a dark pink. Which one gets grounded in order to work with the YZ CDI? I'm not running a battery.
Thanks.
  • Speedracer747-400
Posted March 22, 2008 - 12:39 PM
You should have the following wires coming out of the stator:
CDI Harness
Br-Brown
P-Pink
G-Green
R-Red
W-White
B-Black
Power Wire
Y-Yellow
I think your confusing the red wire for "dark pink". The light pink wire is the one you need to cut. Cut it and hook the end going to the CDI to chassis ground. The end going to the stator can be caped or taped off. In the future if you have problems with the same project try to just post in the original thread. This way the next person doing the same install will have all the info in one place and make it easier for them. Good luck with the lights.:confused:
