Living in Libya, Don't have a flywheel holder, any tricks?
4 replies to this topic
  • segge
Posted March 22, 2008 - 07:54 AM
Hi,
I live in Libya and need to pull the flywheel off of my '04 XR 650. I don't have a flywheel holder or puller. I think I can build my own puller, but not sure about the holder to remove the nut. Any suggestions or tricks on making one or faking one?
Thanks, Steve
  • steed2
Posted March 22, 2008 - 08:50 AM
light duty impact gun or put the bike in 5th and have someone hold the rear brake. that will do it
  • Coolidge
Posted March 22, 2008 - 08:51 AM
Ive seen this done w/a bicycle chain (wrapped around flywheel, then using puller fingers on the chain....) Good Luck!
  • cleonard
Posted March 22, 2008 - 10:22 AM
The brake method works well. If you don't have a air impact gun, put a wrench on the flywheel bolt and hit it with a hammer to get it loose. I have removed many flywheel bolts this way. I never have owned a flywheel holder.
After you get the flywheel bolt out then you need to remove the flywheel. It is on a tapered shaft and does not come off easily. You really need a flywheel remover. It is a large bolt that screws into the flywheel and bottoms against the crankshaft. It is a standard size metric bolt, just really big, like 20mm or so.
  • knuklehead
Posted March 22, 2008 - 10:44 AM
I used the old skool impact (you hit with a hammer looks like big screw driver) to remove the fly wheel bolt, then the right size bolt (that what a xr fly wheel remover is just a big bolt) tighten then rap with hammer then tighten then rap with hammer and pop off goes the fly wheel.
  • Hot  29 replies
  • Hot  60 replies
  • 22 replies
  • 3 replies
