Sludge on Oil filter
5 replies to this topic
  • MountainMax
Posted March 20, 2008 - 04:57 PM
when doing my regular oil changes, about 400km max (mostly highway driving) I noticed some slight creamy sludge on my oil filter and a little cream in the oil after it drains in the pan, It don't look like much, I have only ran it hot once idling for like 4 minutes, shut it off and heard it bubbling for a bit. It almost seems like sludge as in a car engine when you take short runs you get a little sludge and condensation, can this be hapening or do you guys think i have a waterpump seal or head gasket failing?
2006 WR450 4000km
  • clark4131
Posted March 20, 2008 - 09:57 PM
Really monitor your oil and coolant levels over the next cycle and see what it does. That ought to tell you what's going on...SC
  • MountainMax
Posted March 21, 2008 - 02:41 AM
Well I have never had to add any more coolant. But I will mark the coolant level in the overflow and keep an eye on things.
  • chrispy1202
Posted March 30, 2008 - 10:18 PM
Is there any oil sludge floating on top of your coolant when you open the rad cap? If the head gasket goes, i think you should have a white plume in your exhaust out the pipe.
  • face_plant
Posted March 31, 2008 - 09:10 AM
funny question
but do you turn off the fuel when you park it?
mine sat open for 3 weeks and i was doing an oil change, opened the tank bolt and nothing came out AHHHHHHHH
in a panic state i ripped off the bash plate, opened the case bolt and it was puking gas out of the drain hole
it turned my red klotz oil into a foamy blackish nightmare of a sight
  • MountainMax
Posted March 31, 2008 - 12:42 PM
there is nothing in the coolant and no sign of white smoke, and i do not turn off my fuel, I guess I will start to though, just to see.....
