Removing the turn signal control
4 replies to this topic
  • morrpete
Posted March 20, 2008 - 10:47 AM
I have a 95 xr650l. I've stripped the turn signals off and want to remove the control on the H/B. Any idea how to rewire so the headlight and clutch still work?
  • cleonard
Posted March 20, 2008 - 02:25 PM
Remove the control.
Jumper the bike side of the connector so the low (or high) beam is on. you will also need to jumper the safety circuit so the starter will work.
If the clutch perch is part of the control then get a regular perch. One for a XR600 should work.
  • knuklehead
Posted March 20, 2008 - 03:32 PM
Wont that kill his battery.He will need a switch some wear for the head light.
  • cleonard
Posted March 20, 2008 - 03:45 PM
I thought that was in the key switch, not the left hand turn, hi/lo, horn switch. All this would do is permanently select high or low beam and do away with the trun signals and the horn.
  • knuklehead
Posted March 20, 2008 - 03:52 PM
Your right, my bad. Been a while since the L, forgot all about a keyed ign
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
  • Hot  171 replies
