rekluse pro
5 replies to this topic
  • scotty442
Posted March 20, 2008 - 08:08 AM
I have yz450f 07 ,does anyone have rekluse setting suggestions thank scotty442
  • Wiz636
Posted March 20, 2008 - 09:34 AM
In my '06 I started with the recommended 'default' settings but found that it was so tight that I was actually able to brake stall occasionally so I went with the next stiffer spring to raise the engagement/disengagement RPM slightly and now it works perfectly. Definitely go with 27 balls for the nice, crisp engagement.
  • rexbond007
Posted March 21, 2008 - 04:15 AM
i'm seriously thinking of getting the pro. i put a flywheel weight in last year - GYTR offroad. will there be a plus to leaving it in? or should i put back in the stock?
  • gord955
Posted March 21, 2008 - 05:46 AM
I think the Rekluse Pro will work well with the flywheel weight, you may have to play with your engagement set-up to get it the way you want. The setting depends on the type of riding you do. I used mine for MX with a higher engagement, mostly for starts, it worked well. Once you get it working the way you want, it's maintence free. The best feature with the Pro is that you have the best of both worlds, a clutch when you want or no clutch at all.
  • rmzRacer293
Posted March 21, 2008 - 08:49 AM
I would love to try a rekluse, but their like 5 or 6 hundred bucks :confused:
  • scotty442
Posted March 22, 2008 - 08:24 AM
Thank for info snow still on the ground in mn cant wait to ride scotty442
