Clickers
7 replies to this topic
  • MaxPower
Posted March 19, 2008 - 01:48 PM
[COLOR="Green"]I know my spring rates, but cant say I know my clicker settings.
Im going to have to write them down
Do you guys know your settings and what you change them to for different terrain ?
I have a 04 with 5.6 in back
stock in front with Factory Connection revalve
And I like it a lot
I have only ridden in sand since I got it so I dont know what settings are for rocks and hardpack[/COLOR]
  • MaxPower
Posted March 20, 2008 - 07:13 PM
[COLOR="Green"]all the crazy things you guys do to tweak the WR motors (O Ring mods, YZ cams, 700 dollar pipes) and no one fine tunes their suspension other than sag?[/COLOR]
  • SJMC_DON
Posted March 20, 2008 - 07:24 PM
None of us can remember our settings:busted:
I have .48 front and 5.6 in the back - stock valving. I am running 5WT in the front at max recommended height level based on manual. I am 210 lbs. "A" level racer.
Set up for a GP last weekend -
Front comp. - 1 click out from all the way in.
Front Rebound - 6 clicks out from all the way in.
Rear HS comp. - 5 clicks out from all the way in
Rear SS comp. - 1 1/2 turns out.
Rear Rebound - 6 clicks out from all the way in.
I don't know sheet about suspension, I just try and get it right for my taste. I think clicker settings are too subjective to compare with other riders and bikes...
If I am riding tight and tech woods I will usually go out on the compression and slow down the rebound as needed...
  • SXP
Posted March 20, 2008 - 09:10 PM
Damn, Don! That thing must rattle your teeth loose!
  • SJMC_DON
Posted March 21, 2008 - 07:23 AM
Nope... I would normally think the same but for the high speeds and larger downhill jumps with too often a flat landing it really worked well:excuseme: Remember.... this is stock valving, 5WT oil and I come in at a stealthy 210lbs... I like to think that I ride hard too :confused:
  • SXP
Posted March 21, 2008 - 07:52 AM
Here's something you might want to try since you are using the stock valving - at your next fork oil change try Mobil 1 ATF (the full synthetic stuff - about 5 bucks a quart). It's between 5-7W and you will probably have to back out (soften) your clickers about 2-3 clicks. The fork action really feels as slick as snot and the beauty of this oil is that the fork action remains fade free and consistent over a much longer period of time than regular fork oils - a plus under race conditions. Give it a shot. Another benefit is it will give you a little more adjustability as you are already running at 1 out from all the way in. I use it in both my 07 and 99s and love it.
  • Wiz636
Posted March 21, 2008 - 07:58 AM
Holy crap! Don, you need a YZ (that statement might actually carry some weight if I could ever beat you on mine :confused:).
  • SJMC_DON
Posted March 21, 2008 - 08:17 AM
So thats Automatic Trans. Fluid? Thanks I'll try that :confused:
Holy crap! Don, you need a YZ (that statement might actually carry some weight if I could ever beat you on mine ).
Wiz.... All you need to do is steer clear of the barbed wire fences :excuseme:
