noisy gears
8 replies to this topic
  • blackdog9
Posted March 19, 2008 - 01:01 PM
Hi you all!! I own a 2007 WRF 450, and when I disengage the clutch (as in Neutral gear) I hear more noise coming from tthe gearbox. My mechanic inspected clutch discs, the whole clutch assembly...and everything ok.
Though...noise is still there.
Any thoughts?
Thanks
  • doctorchopper
Posted March 19, 2008 - 02:03 PM
my 05 does the exact same thing, i've searched a lot of threads and it seems to be a common problem with the wr's
  • zukrider
Posted March 19, 2008 - 03:12 PM
my 07 does it also when in neutral clutch pulled in its pretty quiet let the clutch out and you here the gear noise.:confused:
  • blackdog9
Posted March 19, 2008 - 04:29 PM
then I guess it`s normal....thanks a lot.:confused:
  • Demo_Slug
Posted March 19, 2008 - 05:55 PM
my 08 does that to. it worried me too. but they all seem to do it.
  • nugstar
Posted August 12, 2009 - 03:47 AM
brand new 09 it make noise disengaged.. was also worried good to hear its normal thing...
  • tribalbc
Posted August 12, 2009 - 06:42 AM
My 07 has always done the same. Figured it was normal.
  • bwardipi
Posted August 12, 2009 - 06:47 PM
same, 08, quite normal
  • Krannie McKranface
Posted August 12, 2009 - 07:04 PM
You need to change your mechanic.
He should know that all modern dirt bikes are quieter with the clutch disengaged.................
