Seal Savers ????
27 replies to this topic
  • MountainMax
Posted March 18, 2008 - 01:00 PM
Hey guys, I was going to put some sort of seal saver of the forks of my 06 WR450 and wanted some opinions, are they good? hard to clean? high maintenance? what kind is best? i see some on zip ty racing i was thinking on getting for 20.00
  • camaroman7d
Posted March 18, 2008 - 01:47 PM
Take a look at Shox Sox, those are the ones I use. I like them better because you don't have to remove the fork legs to put them on or take them off. You can take them off and wash them as need.
  • maximus400
Posted March 18, 2008 - 01:55 PM
Where did you find Shox Sox??
  • camaroman7d
Posted March 18, 2008 - 02:04 PM
My mistake they are actually called Shock Sox (I had to run out and look at the bike). I bought them here http://www.bermmx.com/products.php
  • kanemilo
Posted March 18, 2008 - 03:58 PM
I tried the velcro type didn't like them. Got the long Tusk savers cut them in half and now have two pairs. Ran one set all last season with no problems and have just took them off and put on the second set for this year. Have had no problems with my seals while some of my friends without savers have already had to replace the seals.
  • blurter
Posted March 18, 2008 - 04:55 PM
I've had a set of the seamless ones on since I bought my bike back in May 07 I've had no dramas with the seals after 1600k's of riding in sandy, muddy conditions. I think they're a good idea so long as they're cleaned pretty regulary.
  • dazzabb
Posted March 18, 2008 - 10:49 PM
+1 on the regular cleaning.
I use the Ballards Seal Savers, which require the forks to be removed to fit.
Still bust a fork seal with them though.
  • MountainMax
Posted March 19, 2008 - 02:28 AM
How do you clean the ones you remove the forks to fit???
  • WR_Dave
Posted March 19, 2008 - 03:35 AM
With the seamless ones you just roll them back over themselves and wash them out. I had a set of the velcro on seal savers several years ago and the problem with them is that the dirt that gets behind the area with the velcro acts like a sanding block on the fork tube - not good. For the type of riding we do here in the rockies I wouldn't ride without them. WR Dave.
  • flynbryan
Posted March 19, 2008 - 04:23 AM
+1 for the seal savers. Have used them on two different bikes with good results. As others have said, just make sure you clean under them after each time you ride.
  • xcracer123
Posted March 22, 2008 - 09:34 PM
http://www.bermmx.com/equipment.php
  • LimyWPom
Posted March 23, 2008 - 08:10 AM
WRDave where did you get your seamless savers, I have been using the velcro type not knowing the seamless were that easy to clean, thanks
  • FastRides
Posted March 23, 2008 - 08:20 AM
I had a set of the velcro on seal savers several years ago and the problem with them is that the dirt that gets behind the area with the velcro acts like a sanding block on the fork tube - not good. WR Dave.
Great feedback, Dave. Lots of sand in Nevada and I hadn't considered this. Many thanks. Mark
  • WR_Dave
Posted March 23, 2008 - 01:30 PM
I can get them here at the bike shop with the Moose logo on them or the longer ones with the Acerbis logo on them. I usually buy the Acebis brand and that way I can cut them up and get 3 sets of shorter ones out of one set of long seal savers. Just my cheap a$$ way of doing things. WR Dave :confused:
  • Mutu
Posted March 23, 2008 - 05:11 PM
I like them, they work good.
  • maximus400
Posted March 24, 2008 - 06:04 AM
Thanks, I"ll check them out.
  • techmc
Posted March 24, 2008 - 11:06 AM
Got no responses that were any good, but how are you guys doing it??? See my post couple of years ago, cant keep them on my 06 yz250 would like to but see here what they do!!!!:confused:
http://www.thumperta...ad.php?t=410324
Techmc
  • LimyWPom
Posted March 24, 2008 - 11:57 AM
:confused: thanks for the response WRDave, I just assumed you were using them full length, but I like the sound of that and i will give it a go. techmc all i did with my fork guards was to bend them out sort of straight so that when they sprang back they didnt rub on the seal savers just giving a little more clearance, crude but it worked.
  • WR_Dave
Posted March 24, 2008 - 12:33 PM
Hey Techmc, the first thing I see that may be causing your issues is that you have the seal savers "over" the fork guard slider rings. Take the slider rings out from under the seal savers and put them over the seal savers so they can do the job they were designed for, giving the fork guards something to slide on that isn't the seal saver! Also just use a heat gun to warm up the fork guards and hold them open with a baseball bat or something untill they cool to a better shape. 2 years is a long time to wait for an answer!!!!!! My .02 -- WR Dave.
  • AnimalDan
Posted March 24, 2008 - 12:35 PM
Techmc
I had the same problem. There just isn't much clearance between the guard and the seal saver. The heat gun didn't work too well. The guards are pretty thick plastic and it kept bouncing back. So I strapped a softball inside the guard and then hit it with the heat gun. Let it sit over night. Did it a couple of times, really got the guard hot. Now I have enough clearance, no more rubbing on the seal saver.
