06 Starter lock up question
2 replies to this topic
  • kpflyingv
Posted March 18, 2008 - 10:42 AM
Sometimes my kick starter will act like it's stuck or locked. I put it in gear and bump it and the starter releases. I've seen a thread quite a while back concerning this. My question is whether it's ok to just bump it when it happens or should I go inside to replace something?
Posted March 18, 2008 - 11:16 AM
Depends on why it's "locking up". The starter mechanism itself will not normally do this, but it could if it had a broken tooth on one of the several gears involved. But this will usually feel somewhat different than a failure to decompress. If it's the latter, putting it in gear and bumping the bike backward will always clear the condition up. If it's a broken gear, it may, but the problem may repeat on the next successive starting attempt, as though you had not done anything.
http://www.thumperta...979#post5314979
  • kpflyingv
Posted March 18, 2008 - 11:29 AM
Thanks, I don't think it's a broken tooth on a gear, but just to be sure I'll pull it apart to have a look. Doesn't do this very often.
  • Hot  50 replies
  • 0 replies
  • Hot  38 replies
