4th gear bog
9 replies to this topic
  • Island Boy
Posted March 17, 2008 - 03:13 PM
I have done all free mods on my 07 WR450, AIS removed, Dr. D Full Race Exhaust, JD Jetting (170, 48 and Red Needle at 4th clip, I think) for sea level, 80-90 degree temp.
The jetting (i think) is pretty much spot on but I sometimes notice a bog when i whack the throttle hard in 4th gear (at the lower end). This happens just before a wheelie... on a rare occasion when i think i am in 3rd but i am actually in 4th.
I recently purchased and installed the R & D Power Pump with the stiffer spring and set the ALJ at #40. Throttle response is definitely crisper but the 4th gear bog is sill there. I have adjusted ALJ to #30 and #50 and it's still there.
Can i get rid of this bog? What should i do / change / adjust?
Thanks.
  • Mutu
Posted March 17, 2008 - 06:50 PM
Lockwire AP actuator arm.
You do have an adjustable fuel screw, don't you?
  • KennyMc
Posted March 17, 2008 - 07:05 PM
The JDJetting kit came with the o-rings for the accelerator pump. Did you use one of them?
  • Island Boy
Posted March 18, 2008 - 05:00 AM
R & D told me the stiffer spring i installed does the same thing as the AP lockwire or o ring mod.
I dont have an adjustable fuel screw because i only ride at sea level.
  • Island Boy
Posted March 19, 2008 - 08:33 AM
is it fuel mixture?
  • dugabrams
Posted March 19, 2008 - 09:24 AM
Virtually every bike needs a fuel screw for crisp throttle response (unless you can adjust the stocker properly, which I doubt)
  • Mutu
Posted March 19, 2008 - 11:57 PM
Get one!!! That may clear up your problem! It may suprise you the difference these babies can make to the throttle crispness and up to 1/3 throttle performance. They are cheap (and in my books a necessary) mod to do.
is it fuel mixture?
Yes.
  • Mutu
Yep! :confused:
  • Island Boy
Posted March 20, 2008 - 05:29 AM
Thanks guys... ordering one today!
  • maxtherat
Posted March 20, 2008 - 10:13 PM
When you say that you whack the throttle hard does that mean wide open? If so, since you are using the red needle maybe try the 168 main jet.
