How do you take off the rear brake pedal?
11 replies to this topic
  • klxnewguy
Posted March 15, 2008 - 05:23 PM
I wanted to replace the rear brake pedal. I took the little pin out of the back of the bolt but I can't get that thing to budge? Any ideas on how to get that out? I have an 01 426 that I am going to take apart and clean up. Thanks!
  • KJ790
Posted March 15, 2008 - 05:26 PM
It's probably rusted in place. Try some penetrating oil and force. Make sure you grease it well before puting it back together.
  • 642MX
Posted March 15, 2008 - 05:55 PM
Put a little heat on it. Use a heat gun, there is an o-ring on the brake pivot bolt and you don't want to melt it using a torch.
  • klxnewguy
Posted March 16, 2008 - 07:38 AM
I'll give it a shot with something to work on the possible rust and then heat it up a bit. Thanks guys!
  • timoyz1
Posted March 16, 2008 - 07:53 AM
You took off the cotter pin, but did you take off the nut too?
  • KJ790
Posted March 16, 2008 - 07:56 AM
I think he means the pivot bolt, which doesn't have a nut.
  • SPLATT
Posted March 16, 2008 - 08:18 AM
You can give it a smack with a hammer to help break loose some of the rust as well.Just don't over do it.
Steve
Posted March 16, 2008 - 10:08 AM
Steve
If you decided to try this, find a pin punch that will fit inside the Allen socket of the pivot bolt. By doing this, you can be fairly brutal without doing any damage that will matter in any way.
  • Dveitch8
Posted March 16, 2008 - 11:43 AM
oops rusted in place, time for a new bike! If you can find some, PBBlaster is the best rust breaker I've ever used, amazing stuff!
  • MaxPower
Posted March 16, 2008 - 02:00 PM
[COLOR="Green"]pin punch? Im not clear on that[/COLOR]
Posted March 16, 2008 - 02:32 PM
  • klxnewguy
Posted March 17, 2008 - 03:57 PM
Thanks guys, just some WD 40 and the fact that I had to man up a bit and off she came. No rust. I am going to take the bike down to the frame and powder coat the bad boy. I'll let you know once it's all done!
  • 5 replies
  • 9 replies
  • 0 replies
