wr400/426 wheels........question
5 replies to this topic
  • kevan
Posted November 04, 2002 - 09:34 AM
Have been advised early wr wheels will not fit 2000 model on
is this true and what are the diff.....can they be overcome
have found wheels but cannot confirm the year...
any help would be great peeps
  • smotard
Posted November 04, 2002 - 10:06 AM
Only the 1998 400 wheels are a problem the front is ok but the rear has a different bolt pattern for the rotor and sprocket. I hope this helps you.
  • kevan
Posted November 04, 2002 - 11:26 AM
hi Paul
wheels have disc's and sproket does that mean they'll be o.k. regardless what year they are........
  • GPS Dual Sport
Posted November 04, 2002 - 12:44 PM
I have installed a '98 WR 400 front wheel on my '02 426. There is a difference in diameter on brake rotor and I had to use the '98 axle spacers.
The '02 wheel will not fit the '98 bike. The front brake rotor will not clear the caliper carrier.
I don't know about the rear wheels.
  • jwriott
Posted November 04, 2002 - 01:14 PM
I thought the rear axle diameter was different on the older models as well.
  • smotard
Posted November 04, 2002 - 01:20 PM
If its a 98 the rear rotor is only a 220mm,Your bike has a 240mm, you could fit a rear rotor from a 99-00. Apart from that I don't see anything else that will give you any problems.
