Handlebars
12 replies to this topic
  • dw
Posted November 04, 2002 - 05:36 AM
Would the Jeremy Mcgrath bend be a good bar for me, im about 31inches tall, i gotta consider that the clamps raise the bar a bit too..
I would really like recommendations :)
  • x2smoker
Posted November 04, 2002 - 08:30 AM
If you are only 31 inches tall, I would sugest using the stock bar that comes on a Mattel Big Wheel. :)
  • dw
Posted November 04, 2002 - 08:44 AM
ARrrrrgh im swedish and we dont use inches :) i guess thats really short, im 2 meters tall or 1.98 centimeters..
  • dw
Posted November 04, 2002 - 08:45 AM
Ahhhhh i got it one inch = 2,54 cm .. that would make me
uhmm 78inches or 7,8 as you would say?
  • Air450
Posted November 04, 2002 - 05:27 PM
6ft, 6inches.
  • Woodzi
Posted November 04, 2002 - 05:42 PM
I am 200 cm and I use the McGrath bend bars mounted 19mm up and 22mm forward from the stock position. I like the bend and the height is good when raised 19mm. Without moving them up they would probably be too low for you. The Button bend is higher and works better with the stock clamps.
  • dw
Posted November 05, 2002 - 05:06 AM
The mcgrath bend is 795 wide 90 high 65 in rise
Steve Lamson bend is 802 wide 99 high 65 in rise
also used by ricky charmichael , but i use universal clamps, wich raises it about 20mm :D wich would give me 119 mm high :D
The jimmy button bend is 110mm high, so i think it would be enough for me :)
  • sabin
Posted November 05, 2002 - 09:46 AM
Do you have picture of your bar risers?
  • yamaha.dude
Posted November 05, 2002 - 10:40 AM
I am 2.0m tall, and I have the Protaper Doug Henry Bend - highest and flattest that I could get... these are mounted on a Scotts Triple clamp with the higher mounts, and then for the other end of the equation, I have lowered the footpegs, and tall seat foam is my next ergo modification.
Good luck,
David
  • dw
Posted November 09, 2002 - 05:17 AM
Sabin, yeah well i only got the store picture atm, but i could get a cam and get a shot of them tonight if you want to see them, they are about 2cm high almost 1"
heres the webshop photo of them
http://www.knobby.se...wallStyren1.jpg
its the ones in the lower left corner wich says Styrfäste art nr 9000
yamaha.dude, i used the Steve Lamson bends and the raisers, and it feels comfy for me they are Okay, but i gotta try for myself and advance in height of the bars too, putting just the highest bars i can get on the bike might make me feel uncomfy
/dw
  • sabin
Posted November 09, 2002 - 10:52 PM
The picture is ok.
10x dv!
  • dw
Posted November 10, 2002 - 09:01 AM
Your welcome :)
  • Parx_400
Posted November 10, 2002 - 10:56 AM
cr double high + 10mm taller risers = 125mm hight
