Clutch Problems, my 2006, XR 650 R
5 replies to this topic
  • airblast 1
Posted March 14, 2008 - 12:10 AM
Hi Guys,
Any advice on how to save my clutch for more miles. At the moment I am doing a clutch every 1000km's.
I live in Dubai and we do a lot of desert riding. Parts are not readily available here, luckily I can rely on TT for a steady supply. Are there any heavy duty clutch kits in the market.
Also looking to replace the exhaust, any suggestions?
Cheers
  • hill5150
Posted March 14, 2008 - 01:54 PM
I use the Hinson basket, updated bushing, and magura hydraulic cluthch, and always use OEM clutches, I ride the bike (II cam,eddie, custom pipe,680 motor) like it's stolen.... street and dirt and have had great results w/ this setup..................
  • XR4DEZ
Posted March 14, 2008 - 06:48 PM
Are you still using the stock clutch with judder? If yes pull out everything and go back with 7 stock fibers and 6 steel, clutches will last longer with this pack and pull much harder.This is the kit Honda used in their Baja bikes. If it squeals or moans, don't be frightened.
  • resurrection
Posted March 14, 2008 - 06:56 PM
Theres a HRC kit @ honda check that.
  • hill5150
Posted March 15, 2008 - 09:08 AM
no judder w/ the hinson, remove it, it jerks a bit but it isn't a trials bike........
  • airblast 1
Posted March 18, 2008 - 12:06 AM
Had a look at the Hinson baskets and clutch kits. Can't find a Magura hydraulic clutch to suit the XR650 though?
If I remove the judder it won't have any long term harmfull effect on the bike?
Any advice on exhaust system, so far looking at white bros.
  • 22 replies
  • 9 replies
  • 17 replies
  • Hot  35 replies
  • 3 replies
