First time out the garage - rough steering
6 replies to this topic
  • LoneRanger171
Posted March 13, 2008 - 11:14 AM
I got the 06 out the garage today. First time since October. Checked everything out and fired here up (4 kicks not too bad). After about a 5 minute warmum I decided to put around the block and noticed that the steering felt stiff/heavy. On the stand I can turn the bars pretty easily and don't feel any restriction. I thought it might be fork related however I just had the fork seals/fluid replaced last October. Could it be just first time out bugs with things still being "storage" stiffness? Thanks.
  • Wiz636
Posted March 13, 2008 - 11:19 AM
Then it would seem that your head bearings are fine (or at least not bad). This may sound silly but did you check to see if you have any air in your front tire?
  • USED YZ426F
Posted March 13, 2008 - 11:22 AM
Check the steering stem to ensure that it is not loose.
  • LoneRanger171
Posted March 13, 2008 - 11:50 AM
I checked tire pressure (after ride) and it was a little low so maybe that was part of the problem. I hope its not fork related - the forks felt really stiff last year after the fluid change. I think the dealer put in a heavier fork weight oil and my initial impression was that it was very stiff. I won't really know I guess until I get out for a track ride but may need to take out some fork oil to soften the feel.
  • William1
Posted March 13, 2008 - 12:35 PM
Check the damping settings also.
  • ker-b
Posted March 13, 2008 - 12:37 PM
I would check the bearings...friend of mine had same symptoms and found the bearing grease was not really there and they were starting to sieze..
the weight of the bike off the stand puts more pressure on the bearing than on the stand.
He had never greased them after buying it new...they don't really put alot on em at the factory.
  • Ga426owner
Posted March 13, 2008 - 08:22 PM
when is the last time you checked the steering bearings or the lube in them?
  • On January 15, 2017
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  30 replies
