Engine oil blues...
10 replies to this topic
  • Richard56
Posted April 25, 2002 - 02:43 AM
It is normal for WR 400 F to drip engine oil from the header overflow pipe(the pipe that comes out from the top of the engine)?
What type of engine oil should I use, Mineral base, Fully synthetic or Semi-synthetic?
Puzzled...
  • YAMAKAZE
Posted April 25, 2002 - 04:15 AM
Yes it is quite normal, Don't sweat it, Everything is alright. There are several different oils in use I personally use Golden Spectro 15/50...Great for the racing that I put my WR through each season. You will want to purchase a Magnetic drain plug from Terry Cable for your ride as extra protection.
Do a search on: Engine Oil
There have been endless discussions on this subject.
Bonzai :)
  • jamracing
Posted April 25, 2002 - 05:06 AM
Does the magnetic drain bolt catch allot of heavy metal? When I drain my oil, I'll ocassionally stick a magnet in the oil stream, but I usually don't get too much stuff.
  • MOmilkman
Posted April 25, 2002 - 05:29 AM
I have the Ty Davis plug and you ask if it catches metal?
Check out this pic of the shavings it grabbed from one of Ty's bikes.
  • Richard56
Posted April 25, 2002 - 05:44 AM
What oil should I use then?
  • MOmilkman
Posted April 25, 2002 - 07:24 AM
Im the same as Yamkaze. I use Golden Spectro. Semi-synthetic.
Awesome oil. Ive ran my bike for 3 going on 4 years hard on this stuff and it still holeshots.
Change it every 3 rides minimum.
  • jamracing
Posted April 25, 2002 - 07:37 AM
My, what a pretty flower you have! That's pretty brutal. I'll order one today :)
  • lewichris
Posted April 25, 2002 - 08:28 AM
yamalube 20W-40 is always a good choice. Personally i use Mobil 1 15W-50 synthetic not the motorcycle kind the car kind. These guys on here talked me into it.
Chris
  • Dean400
Posted April 25, 2002 - 02:20 PM
I am wondering what would the advantage of the car Mobil 1 oil be over the motorcycle Mobil 1 oil? I read couple of magazines that said not to run car synthetic oil in bikes. I am no oil expert, but I thought I should raise the question.
  • F-Pilot
Posted April 25, 2002 - 02:48 PM
Please don't raise this issue again! :)
Just do a search on "oil" from the menu at the top.
This seems to be a very touchy subject and usually goes on for hundreds of posts.
Personally, I use Mobil 1 15w50 and have since my '98 400. Never had a failure or problem.
I think that most oils are ok to use, you just need to change it every other ride and clean/replace the filter every other oil change.
  • neWRiver
Posted April 25, 2002 - 03:02 PM
The real question is, what is the advantage of the motorcycle Mobil 1 over the car Mobil 1? Nobody seems to question whether or not MX4T is a good oil choice for your bike. We just aren't convinced yet that the difference between it and plain old Mobil 1 15w50 is worth a couple bucks a quart. The key debate point is "friction modifiers".
I'd suggest doing a search to read the old threads, but you'd still not be able to answer the question. Best advice you'll come away with is to change it often no matter what you use. My manual says to use an oil which does not display the EC rating. It says nothing about using only a motorcycle specific oil.
