honda and yamaha hubs
4 replies to this topic
  • fastback959
Posted March 12, 2008 - 07:38 PM
any one know if i can fit a 04 cr450 rim and hub on a yzf426?? the rim size is the same but i don't know if the hub size is the same.... :thumbsup:
  • KJ790
Posted March 12, 2008 - 07:52 PM
I doubt you can easily do it. The key fitting points to a hub are the distance from the center to the rotor/sprocket, the axle diameter, and the distance between the fork lugs/swingarm depending on if it is front or rear. It is easy to get bearings from a bearing shop that will make the right axle size if it is different, and wheel spacers can by made easily on a lathe. The biggest issue is the spacing of the rotor and sprocket. If you can make them fit correctly, then you can make the wheel fit.
  • gbalias
Posted March 12, 2008 - 08:25 PM
no go.
the hondas have a 32 hole hub in rear.
not to mention the issues stated by KJ, plus the difference in diameter of the swingarm opening.
  • KJ790
Posted March 12, 2008 - 08:37 PM
no go.
He said rim and hub, so the number of spokes is not an issue.
  • wheeldude
Posted March 13, 2008 - 05:10 AM
Hondas use a 25mm rear axle and the YZ uses a 22mm rear axle. This along with what KJ talked about should have you thinking "I need a YZ hub" .WD
  • 10 replies
  • 0 replies
  • Hot  47 replies
  • 9 replies
