07 xr650l help
10 replies to this topic
  • gusbomb
Posted March 11, 2008 - 07:06 PM
looking to do somthing with the ugly taillight and plate holder. just looking for a few ideas.
  • jonr3
Posted March 11, 2008 - 07:20 PM
I replaced the rear fender with a CRF450 fender, added a Baja Designs tail light/brake light, and replaced the turn signals with some small flush mount ones I found on ePay.
  • martinfan30
Posted March 11, 2008 - 08:13 PM
I had the same idea.. Go with the CRF450 rear, and the XR400 front fenders.
  • gusbomb
Posted March 12, 2008 - 03:17 AM
hey martinman i see u took off those stupid looking air scoops did that have any adverse cooling situations.
  • martinfan30
Posted March 12, 2008 - 03:58 AM
Maybe 5 deg...
If you install an after market tank like my Clarke 4 gal, it eliminates the use of the elephant ears. I broke one once and it was 100 bucks to repl. from Honda... I just ripped em off and sold them.
  • Denn10
Posted March 12, 2008 - 09:06 AM
there $20 here http://www.procycle.us/main/dskit.htm scroll down a little and youll see the WPS right below the XR style light
  • jeanluconze
Posted March 12, 2008 - 10:39 AM
[quote name='martinfan30']I had the same idea.. Go with the CRF450 rear, and the XR400 front fenders.
save $$$ and trim your stock fender back 3 to 4 inches. Rough cut the tip off at 2 inches back, then use the piece you just cut off to trace the new cut line so it's looks stock. Sand it down and use a small butane torch to just barely re-melt your final cut edge to give it the factory gloss look. Careful or it will burn and look like shit.
  • evomx971
Posted March 12, 2008 - 12:49 PM
Anyone happen to be using the WPS or an XR style taillight in conjunction with a Promoto Billet rear rack? I bought one of the WPS lights after seeing how nice it looks on the stock fender, but once I got it I realize it's actually going to be tucked up under my promoto rack quite a bit. Hopefully there won't be a visibility issue, especially since I run a GIVI top case on the rack sometimes and it sticks back even further. Probably not since although it looks hidden with me looking at it, traffic sees it from a lower angle (except for maybe tall trucks, semis, etc?).
  • larsk
Posted March 13, 2008 - 06:54 AM
I have the WPS light with Pro Moto billet rack and there is no problem
  • Motosprtman
Posted March 13, 2008 - 07:27 AM
I bought the 20.00 light from procycle as Denn showed, got it quick and ez to connect and works fine and best of all looks sanno.
  • Denn10
Posted March 13, 2008 - 10:49 AM
i need to get off my arse and order it also, it plugs right in right?? or do you have to cut the connectors off and wire/solder yourself?
  • Hot  35 replies
  • 9 replies
  • Hot  60 replies
Washington
  • Hot  32 replies
  • 22 replies
