My plan for "uncorking" a 07 650L
7 replies to this topic
  • rotary16
Posted March 09, 2008 - 07:36 PM
Here is what I think may be a good plan.
Removed snorkel.
Remove smog equip.
Add Uni filter.
Install FMF Q2 slip-on.
Now, I am pretty much confused by what jetting changes will be needed. Can someone advise? I have searched the issue here, and just get more confused each time. I really don't want to go the "Daves Mods" route and would prefer to purchase a packaged kit (I know, $$$). I know there is a ton of knowledge and experience here. I am looking to improve the driveability and all around performnce that mnay are claiming from the "uncorking", I have no specific expectations aside from improving warm-up and getting rid of that decel "popping".
Thanks in advance.
  • martinfan30
Posted March 09, 2008 - 07:42 PM
Good plan of attack. I also did the DJET kit on mine when I first bought it. Worked great. The only thing is, the kit doesnt come with a richer pilot. This is what causes the warm up and popping on decel issues. I assume you are under 2000 ft.? Put in the DJET kit, clip in the 3rd position from the top. Then buy a 55 pilot for that carb. This will fix your popping and warm up issues. Also, you can drill the outer two slide holes to 5/32" to help with throttle response. You will also want to grind the stop tab off of the float bowl. That way you can get some adjustment out of the fuel screw... 2 1/2 turns to start.
  • Denn10
Posted March 11, 2008 - 06:28 AM
55/58 pilot and i think most use the 165 main out of the DJ kit which is about the only kit you can get i think, or at least one of only 2 carb jetting ive seen on here, either stock jets or the DJ kit.
Whats your elevation and where about in SC?
Welcome to TT!!!
  • Motosprtman
Posted March 11, 2008 - 06:32 AM
I agree I run the DJ kit with the same setup as Martinfan. Makes it start ez and run strong.
  • DBM
Posted March 11, 2008 - 03:33 PM
I had great results with the "Dave's Mods" to the stock carb. Go to www.thumpertalk and do a search. I can send you a e-mail attachment that explains everything if needed. You must follow the instructions exactly to see the best results. I buy all my jets and stuff from Carb Parts Warehouse dot com. I also did the following:
grind the welds smooth on the header pipes were they bolt to the engine for max flow
use 14/48 gearing for dirt and 14/45 for street
The FMF Q2 will seem kinda loud with the stock header, but mine was much quiter with a XR600R "power bomb" header.
I have spent the last year setting up my 07 XR650L and would be glad to help out. Send me an e-mail to dbm14@tampabay.rr.com
DBM
  • DBM
Posted March 11, 2008 - 03:34 PM
Sorry, I meant go to www.4strokesonly.com and do a search for Dave's Mods. That's where I found it.
DBM
  • rotary16
Posted March 11, 2008 - 04:39 PM
I'm located near North Augusta, SC, small town named Graniteville. We are on the western border with Ga. Near Augusta, GA. (Master's :thumbsup: ).
Elevation is around 500' ASL.
Thanks for the input.
  • dstark
Posted March 11, 2008 - 06:39 PM
I agree with the daves mods theory, I bought the Djet kit for my '06, and wasnt too impressed with it, so I did daves mods, much happier. Although I did leave the DJ spring in. I run 55/160 at 2000 ft. Works pretty good:thumbsup:
  • 17 replies
  • 9 replies
  • 22 replies
  • Hot  29 replies
  • Hot  186 replies
