wr - yz timing specs
8 replies to this topic
  • djrevz
Posted March 08, 2008 - 08:02 AM
useing the yzf450 timing specs and a wiseco piston will this make the bike as reliable or less reliable? also as the wiseco piston helps more with compression would this make it unreliable if kept the wr timing?:thumbsup:
  • MountainMax
Posted March 09, 2008 - 09:10 AM
if you use a higher compression piston, the electric start may not work proper, im running yz cams/timing with no problems here though i never changed the piston
  • djrevz
Posted March 09, 2008 - 12:09 PM
i dont like the elec start i wont ever use it lol i find it boring my self the kick start i 1 of the main reasons for the off road style bike, so apart from the problem with a elec start would it be better with a wiseco piston or a standered 1? thanx in advance
  • MountainMax
Posted March 09, 2008 - 02:45 PM
A higher compression piston will give you more power but you will need higher octane fuel, if your running 91 now (and you should be) you will probabally need 93 octane then.
  • Face plant
Posted March 09, 2008 - 02:57 PM
I don't get it, why didn't you just buy a YZ instead of a WR then?:thumbsup:
  • MaxPower
Posted March 09, 2008 - 03:02 PM
[COLOR="Green"]for real excitement you should take you kicker off and bump start your bike every time you ride if you find the estart boring[/COLOR]
  • TWILES
Posted March 09, 2008 - 03:40 PM
I'm going to start playing around with the motor on mine after suspension. I've thought about a 13.5/1 piston but who wants to pay anymore for gas than they have to. If I were you, I'd try the YZ cam and a lighter flywheel. Trail Tech makes a -6oz. I'll put one on mine. That should make it feel lighter around half throtle. I can't stand the "tractor-like" power it has. I want it to spin and fell like it comes alive more when I hit the gas. It feels too much like a lawnmover motor even uncorked. I guess thats great in the desert but "PTO" power sucks when you need 2-stroke power.
Here's Trail Tech's website. http://www.trailtech.../flywheels.html
  • djrevz
Posted March 10, 2008 - 01:41 PM
the reason i want the wr is i will use it all the time when the yz are a fully off road bike and need piston and rings after a certan amount of hours
  • djrevz
Posted March 10, 2008 - 01:42 PM
besides the other reason with not using the elec start means taking it off its a lil wait off the bike every bit of wait helps lol
