Cylinder / Crank Case gasket issues
2 replies to this topic
  • jameskiehl
Posted March 06, 2008 - 12:37 PM
Hi Guys,
looks like i have a huge leak between the cylinder and the crank case, right at the coolant tube/o-ring connection (front of engine, runs between oil channels). I disassembled the top end, and saw that the hole in the gasket that fits over the coolant tube/oring connection was deformed. would this be a 'blown gasket', and could that alone be the reason for coolant just flowing freely out of the channel?
Thanks,
Jim
Posted March 06, 2008 - 12:58 PM
The O-ring should have sealed the coolant, but it may have shrunk. The base gasket on engines that have O-rings at that joint are not intended to hold the kind of pressure typically generated in a cooling system. It was proably no more than a shrunken ring, and just replacing the ring and gasket will most likely fix things.
  • jameskiehl
Posted March 10, 2008 - 09:42 AM
OK, parts should be here tomorrow, so i'll let you know how it goes.
thanks,
Jim
  • Hot  28 replies
Motocross
  • Hot  491 replies
  • 0 replies
