Re usable oil filters
17 replies to this topic
  • jrny426
Posted March 06, 2008 - 08:41 AM
Hey
I was wondering the average opinion on thse things was..
i have one in my 426 and and have no issues..now I have 07 450 and the Yammy dealer says not to use them ..is this so they can sell more OEM filters or do they have a legitimate claim,(something about flow rates).
Posted March 06, 2008 - 09:21 AM
First, I have to ask whether you are certain that you have a re-usable filter or one of the OEM brass screen types. The brass filters were superseded by the fiber (paper) type in '03, and are not truly reusable because they are too delicate to hold up under repeated cleanings without sections of the screen being opened up. They also cannot filter very well, no finer than 80 microns or so.
The Scotts stainless steel mesh filters are a much tougher filter. At one point, I ha done that was 4 years old, and when I last had it tested, it was still not allowing 34 micron particles to pass. I personally will not use any of the cheaper "copy cats".
As far as flow, one inch square of the mesh used in Scotts filters will flow 1.9 gallons of 90 weight oil per minute at only 1 psi pump pressure @ 70 degrees F. The YZ filter has about 16 square inches of filter media in it, which would figure out to 30 gpm. If you cut that to 20 gpm to allow for the pleated construction, it's still faster than a typical gas pump, and the oil pump in your bike will never be able to match that rate. Remember, we are talking about cold 90wt. "Paper" filters, on the other hand, will usually flow so poorly when cold that the bypass valve at the filter base normally opens on a cold start, leaving you temporarily without a filter.
In the particular case of Ready Racing filters, the cover they are shipped with does have smaller oil drill ways in it than the OEM cover, and that may be what they meant by "issues with flow".
IMO, the Scotts is simply a better filter than paper, although the ideal thing would be to have one of each in series. The Scotts first to absolutely stop everything larger than 34 microns, and then a paper filter to catch some of the finer stuff. There is a legitimate argument as to which is the better filtration scheme, though.
Read:
http://www.thumperta...297#post4676297
  • jrny426
Posted March 06, 2008 - 09:29 AM
Thanx GR
I have Ready Racing the 426,I havn't seen Scotts where I shop but should be no big deal find.Too bad those covers don't fit they look coolas
Posted March 06, 2008 - 09:35 AM
The Ready filter "seems" to be OK if you use it with the OEM cover, but as I say, I don't trust them completely.
  • Markopolo400
Posted March 06, 2008 - 05:24 PM
At least with my 1999 YZ400F engine, the Ready Racing SS filter does not work with the OEM cover.
  • 642MX
Posted March 06, 2008 - 06:15 PM
Is there a difference in the covers?
Posted March 06, 2008 - 07:56 PM
Yes. First, it lacks the tab extending from the center oil port that prevents the filter from being installed backward, so naturally, people do actually put the filter in backward and cut of the flow of oil to their engine.
Secondly, the oil passages in the cover are smaller that the stock one.
  • 642MX
Posted March 07, 2008 - 06:05 AM
I see. I have 2 of them. Both of them leak, even with new O-rings. I contacted Ready, and they told me to send them back for replacements. I'm not sure if they had machined the outer O-ring position too deep, but it appears like they did. Anyways, I'm suppose to get some free air filters for my trouble.
I may just use the stock covers, but I like the black ones. :thumbsup:
Posted March 07, 2008 - 06:38 AM
That's another issue. You aren't the first one to complain of a leak there, and apparently the problem is that the groove is cut wrong, just as you said.
Double check on using the stock cover. There seems to be some disagreement as to whether it works or not.
  • USED YZ426F
Posted March 07, 2008 - 07:03 AM
A can of Krylon will make the stock cover black.
  • 642MX
Posted March 07, 2008 - 07:55 AM
True.
  • 642MX
Posted March 07, 2008 - 07:57 AM
I'll take a good look at the filter before I put the stock cover back on. Ready told me it would be okay to use their filter with the stock cover, but who knows....
  • Ga426owner
Posted March 07, 2008 - 08:05 AM
I have both Scotts and a CRT oil filters - they both work great and reclean reinstall no problem
  • trailsweep
Posted March 07, 2008 - 09:04 AM
I'm using the stock cover with the their filter and it does work, by the way do you call them to get the new cover?
  • 642MX
Posted March 07, 2008 - 09:22 AM
I emailed them. Good to know about the filter, thanks
  • TobyB
Posted March 07, 2008 - 09:34 AM
Grayracer,
I am going to get a Scotts soon based on your recommendation. What is your process for cleaning it and how often, every oil change or certain hours?
Thanks
Toby
Posted March 07, 2008 - 09:53 AM
Scotts says on their web site:
Simply remove the filter, rinse in clean solvent and replace it, you're done. The filter can be cleaned with solvent, kerosene, aerosol carburetor cleaner, or any other degreasing agent, even common dish soap. You can even blow air through the filter from the inside out to remove any small particles or cleaning agent from the screen if you so desire
I use solvent (mineral spirits), then carb cleaner, then air.
I hold the filter by its ends so as to keep the solvent in the tank from entering the filter without being filtered, then swish it around some. Then I spray carb cleaner through from inside to out, then blow through it with compressed air. Takes about 2 minutes.
  • Whyzee429
Posted March 07, 2008 - 11:22 AM
i have two friend with leaking RR covers....makes me want to try Scotts
  • On January 15, 2017
  • Hot  28 replies
