taking cases apart 06 yz 450
4 replies to this topic
  • ThumperKid250F
Posted March 05, 2008 - 09:20 PM
well as some of you no from my last post about blowing up my 2006 yz 450 that i now have to split my cases since i need a new crank and i got metal all over the place so how hard is it to split the cases on theses bikes.
ive never split cases befor but i realy want to learn how to do a bottem end, i can do a topend but just not the bottem..
the thing im scard of is that when i split them that gears and parts are just going to start falling allover the place ( TRUE OR FALSE)
so how hard is it?
  • todds924
Posted March 05, 2008 - 10:07 PM
so how hard is it?
If you can do a top end, you can do a bottom end. Everything you need to know is in your service manual.....follow it and you will be ok. If your careful the tranny shafts will stay in the case. The hardest part of putting a bottom end together is putting the tranny shafts/ shift forks/shift drum all in the case half together..especially if you've never done it before. Everything should stay in the lefthand side of the case when you take it apart.
Posted March 05, 2008 - 10:19 PM
As you split the cases apart, working from the right side, you will be able to tap each shaft toward the left case, so that the complete transmission ends up in the left case with the right side off. Otherwise, as Todd said, follow the manual, and you'll be fine.
  • ThumperKid250F
Posted March 06, 2008 - 10:37 AM
thanks guys also is there any special tools i need for this job..
:thumbsup:
Posted March 06, 2008 - 10:52 AM
You will need a flywheel puller. Get the right one for it, and don't substitute anything else.
Otherwise, you won't really need anything special. If you look at the picture at the top of 4-93 in your manual, you see a puller being used to push the crank out of the main bearing. This may or may not be needed, but if it is, the puller is a common, garden variety tool that you can find anywhere, and the hardest part may actually be finding two metric bolts long enough to be used for that purpose.
The only other thing is a valve spring compressor, and if you're going to have the head gone over, you should really just let a specialty shop do that.
  • 10 replies
  • Hot  47 replies
  • Hot  113 replies
  • On January 15, 2017
