What parts from my 06 YZ450 not fit on a new 08?
3 replies to this topic
  • baymen12
Posted March 05, 2008 - 02:10 PM
I've got my 06 blinged out! I want to know what parts go with the bike and what I can salvage for my 08:
Dr. D carbon exhaust
Works connection skidplate
asv levers
Enduro engineering rear disc guard with complete disc carrier
new plastics and graphics (2 sets)
Rad mfg. wheels
aluminum throttle tube
moose rad cages
Sunline ti pegs, fuel screw and shifter
stainless steel oil filter
e-line carbon fiber fork protecters
oil fill plugs
GYT-R case saver (right side)
thats all I can think of. Let me know what I can save. Most of this stuff only has a coulple of rides on it (read here BAD CRASH)!
  • stroker101
Posted March 05, 2008 - 02:37 PM
oil filter, oil fill plugs,ti-pegs(08 has them already),shifter,asv lever for front brk is diff. between 06 and 08,fork protectors...lower or upper? lower will not fit from 06',exhuast may fit,throttle tube should fit...
  • andy250
A few things won't fit due to the new front brake for 2008.
Your ASV brake lever will not work. The new C5 part number is BLH13, and the F3 is BHF313.
Your fork protectors won't fit either.
You'll need a new brake side spacer for your front wheel. I'm sure if you give Rad mfg. a call they can hook you up.
Everything else should fit...
  • todds924
Posted March 05, 2008 - 10:25 PM
asv levers
Rad mfg. wheels
moose rad cages
oil fill plugs
Exhaust will fit for sure, Clutch lever will/ brake lever will not. Rear disc guard will . Plastics and graphics will. Wheels will but your going to need different spacers for the front wheel. Throttle tube/ case savers/ oiul filter/plugs all will work. Skidplate will work.
  • 0 reviews
  • Hot  47 replies
  • 9 replies
