wr sprokets
9 replies to this topic
  • ECK224
Posted March 04, 2008 - 10:11 AM
just wondering if any body has changed out there sprokets what were the results good or bad
  • Johnny34
Posted March 04, 2008 - 12:24 PM
I dropped a tooth on the front and added one in the back to get the gearing I needed for the trails here in Oregon. Steep, narrow, slow speed technical trails. Rocks, tree limbs, water crossings, etc... If I was riding open desert I'd stick with the taller stock gears.
  • ECK224
Posted March 04, 2008 - 03:48 PM
I mostly ride the tight technical stuff, most hill climbes I only get down to
2nd then start feathering the clutch, because 1st seems to be to low and just wants to loop me out.
  • ozfam4
Posted March 04, 2008 - 04:22 PM
I recently went from the stock 13/50 to a 14/51 combo. I ride single track,some fast and some extremely technical. First was to low virtually useless. 14/51 seems to even things up a little.
08 WR 450
  • byggd
Posted March 04, 2008 - 04:37 PM
I run a 13/50 in tight stuff and 15/50 for on road and desert.
  • ECK224
Posted March 04, 2008 - 05:09 PM
I got a 15 today, going to try it this weekend
  • TWILES
Posted March 04, 2008 - 06:47 PM
I haven't done it to mine yet but on my 05, first it too low for anything and 2nd is too high it tight stuff. I'm going to go up to a 52 rear and try to lower 2nd a little. I'm going to put a YZ ex cam in it too. If nothing else, I might get a little wheel spin in 2nd so if it won't lug down that low, it will spin the tire and won't have to. I miss 2strokes.
  • MountainMax
Posted March 04, 2008 - 07:04 PM
I went up to a 15 up front and down to a 48 on the rear, mostly for on the road driving to keep the RPM's down a bit lower so i can cruise at 100km/h all day without the engine screaming. I can still drive it fairly slow in tight stuff but it's noticibly harder then stock gearing for the slow stuff, all depends on where you drive i guess to find what's best for you.
  • ECK224
Posted March 05, 2008 - 08:47 AM
I was going to go down a tooth in the back, but I dont think it would be that noticable I'll be running 15/50 I think it's going to work good
  • WRC
Posted March 05, 2008 - 01:39 PM
I dropped a tooth on the front to a 12, it has made a world of difference for me. I ride mostly tight stuff rutted tree lined trails.
