04' WR450 burnt valve?
3 replies to this topic
  • poke450f
Posted March 03, 2008 - 06:30 PM
I am having a hard time starting my wr450, it only has 900 miles on it but takes up to 25 kicks to get it to run. Once it is started and warmed up, at full throttle it misses. Could this be a burnt valve or something else? I have never had to kick it more than 5 times in the past to start.
Help please, Thank you.
  • dirtysouth
Posted March 03, 2008 - 06:42 PM
Check Compression and/or do a leak down test:thinking:
  • PBDBLUE
Posted March 03, 2008 - 08:22 PM
Tough to do a compresssion test with the autodecomp mechanism. Start by checking the valve clearances. These bikes do not have a history of eating valves. Have you checked the carb for clogged jets, etc?
  • Mutu
Posted March 03, 2008 - 09:25 PM
Yep. I'd do valve clearance check (it's very easy to do) and clean out the carby.
Make sure you have fresh fuel in it too!
