2002 wr426 won't idle
2 replies to this topic
  • ktmlane
Posted March 03, 2008 - 07:20 AM
the motor is getting to where it won't idle correctly. Is there a part number for the jet ket and can any one tell me if this bike has the gray wire I need to disconnect? I did the throttle stop fix when new.also put a white bros pipe on it .
thanks for any info.
  • matt4x4
Posted March 03, 2008 - 08:07 AM
Has it been stored for a bit recently?
Sounds like your pilot circuit may be clogged.
First thing I'd do is clean out the entire carb if you're pretty sure it isn't valves or rings.
  • William1
Posted March 03, 2008 - 11:51 AM
Sounds to me like the valves are tightening up. Check the clearances.
