Edlebrock getting better
9 replies to this topic
  • Krannie McKranface
Posted March 02, 2008 - 05:46 PM
I have had a hanging idle and a slight decel pop since I last put the Edlebrock on, so I thought I would fiddle today and solve it.
I found that the 19e needle was rich, at 30 clicks out.
I found the pump was lean.
So, I added 15 degrees more turn on the pump adjustment, added a expansion spring to the throttle linkage, and set the needle at 24 clicks out.
Major improvment everywhere. The extra power from idle to mid makes the bike feel 80 lbs lighter. I now can lift the front wheel from a normal sitting postion first through third with just throttle.
It runs so much better, that I now want more!
Where's that HRC kit anyway??
It's weird how having it rich on the needle, yet lean on the pump would yeild a lean condition on the decel.
  • husky123
Posted March 02, 2008 - 06:14 PM
Sooo, you're keeping it right?
  • DREWBUSH
Krannie-
you are 30 clicks out from full rich? I think you and I have almost the same mods and I am at 12-14 clicks from full rich(clockwise all the way in) with the 19e. And I thought I wasnt rich enough. I might have to tinker with my carb some more. Its just a pain to unbolt the tank and adjust the needle, so I adjust it and ride it for a while and see how it feels.
Posted March 02, 2008 - 06:46 PM
Welllllllllllllllllllllllllllll............... :smirk: :ride: :)
Posted March 02, 2008 - 06:49 PM
Krannie-
I am now 24 clicks from full lean. (from 0 out 24 clicks clockwise).
I have the adjuster top attached.
I have taken the tank off over 30 times by now.
I don't bolt anything back on when I test it, just attach the fuel line.
I leave the shrouds attached to the rad's and just unbolt from the tank.
  • bork
Posted March 02, 2008 - 06:59 PM
I thought the saying was " right rich & left lean" in other words screw down adjuster clockwise until it stops is the richest. Start turning counter-clockwise is getting leaner. Maybe there are different Edelbrocks ? Mine is on my XR600R. FWIW
Posted March 02, 2008 - 08:20 PM
Yes, clockwise increases richness on ALL Edlebrock 'quicksilver' pumper carbs.
The setting is 'out from full lean', unlike fork clickers, which are 'out from full hard', which is going the other direction CCW.
Always start leaner than you want, and head toward rich. If you start too rich, it will never start.
  • DREWBUSH
Posted March 02, 2008 - 11:47 PM
I know about taking the tank off many times. I actually just unbolt the tank and tip it up a little and slip my hand under. Its kind of a tight fit but I can reach the adjuster. So We may be at about the same adjustment, you are counting from full lean, and I am counting from full rich.
Posted March 03, 2008 - 05:52 PM
Yeah, I've adusted it a few times that way too.
  • Thumpage
Posted March 04, 2008 - 08:17 PM
Boy Krannie, you sure are making things confusing for some guys out there. Actually the proper explanation of adjusting the needle is stating from 'full rich' not from full lean. So in proper terms you are 8 clicks out from full rich. (32 total clicks of adjustment). :thumbsup:
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
  • 4 replies
  • Hot  186 replies
Honda XR650L 2016
  • 0 reviews
