MXA's list of kx250 Hop Ups
6 replies to this topic
  • PAdaytonaman
Posted March 01, 2008 - 04:07 PM
In the latest issue of MXA they list the best mods for the kx 250. They list:
Larger rear sprocket (tightens up the gearing, less gap from 2nd to 3rd)
22mm offset triple clamps(lessens the push in the corners)
linkage(gets the shock to ride in the middle of the stroke and lowers height)
pipe, the stocker is too loud after a few rides.and hp gain in the middle(2hp)
and a few other's
Who here has done them and what do you think. Are these changes worth it?
DO these same mods apply for an 07 as well?
  • asgrayasitgets
Posted March 01, 2008 - 04:20 PM
i have an 07 and i put on the RG3 triple clamps (22mm)- way better control in cornering. i put a pro circuit TI-4 pipe on and you could notice the increase, but it also changed around where the power was. so after using the stock for a while and then putting on the pipe, i had to learn to ride it again. with that pipe i never touch 2 gear except for starts. always 3 and 4 on track. and i believe i put on a larger sprocket in the back, this always helps i find.
what i would like to know if anyone has put any hot cams in their bikes and what difference it has made. also looking to put a higher compression piston in and wondering if it is worth it. i would guess it would.
thanks
  • Mike McCutcheon
Posted March 01, 2008 - 06:29 PM
I have a 08 that I put a FMF Ti Core slip-on and Hot Cams in. I didn't try each separately but I can tell you the bike really pulls better, esp. in the mid-upper mid range. I let a friend ride it who has the hi-compression piston and FMF full Ti megga bomb system on his 08 and he liked my set up a little better. He ordered cams the next day. He rides the Pro class and I ride the Vet classes by the way. Cams are the best bang for the buck I think. I like the stock gearing best with my set up. The improved mid range closes the gap between 2nd and 3rd. Man this bike is fun to ride!
  • joshb
Posted March 01, 2008 - 06:31 PM
the rags irritate me they don't know what they're talking about just ride it. don't need clamps unless your pro or close to it. i've never felt a push in corners.
  • Gurdy
Posted March 01, 2008 - 07:25 PM
I agree with Mike, Hot Cams stage 1 rocks on this bike best mod you can do
  • Doofosmitch
Posted March 02, 2008 - 05:27 AM
Yep me either.
Unless your name is Chad Reed, James Stewart, RV, etc etc...
Then you don't need mods.
You can change the looks of your bike ( i have )
But the motor is good enough and the suspension could do with revalving depending on your weight.
  • Johnny_On_The_Spot
Posted March 02, 2008 - 08:32 AM
idk compared to the other thumpers ive ridden (05 yz250f, 06 crf250) it handles much better, but i do notice a push on flat turns after coming off a yz125. i still have to get used to the bike tho:excuseme:
Unknown '08 gas/air issue by thopter_jr
Dirt Bike   Make / Model Specific   Kawasaki   KX250F
  • Hot  36 replies
Motocross
Electric bike smoked by a 250F by redrider144
  • Hot  387 replies
Opinions Needed for Service Plan by Holeshot1982
  • Hot  44 replies
2015 kx250f hard start and wont idle by nsego905
  • 2 replies
2009 kx250f valves and piston, Help?! by tpaden10
  • 3 replies
