reviews for 2000 WR400???????
13 replies to this topic
  • tarlint
Posted February 29, 2008 - 07:10 PM
Riders,
I am a new rider and looking at buying a 2000 WR400 in really solid shape for $2000. My question is this...............how do these bike rate when it comes to maintenance, durability, reputation, etc. I have been told that this was (I think) the first year of the WR400 as a "higher class" enduro or trail style bike. Any known problems with this bike or year?
Thanks in advance for your opinions.
  • ridinredneck
Posted February 29, 2008 - 10:48 PM
actually 98 was the first year. i have a 99 wr400f. had good luck out of it. just change the oil regularly and maintain the air filter. and you might want to check into a new timing chain for one that old. just to be safe. also, if you are a new rider, ease in to that bike. the wr 400's have a lot of power.
  • Birdy426
Posted March 01, 2008 - 11:13 AM
I thought WRs became 426's in 2000...still had SS valves ('01's up got Ti). Only issue with the 98-00 WR400/426's was a bit of a clutch problem. A few 01 up parts solves it. Also the 426's had larger small end rod bearings than the 400s.
Overall, it doesn't matter if it's a 98-02 400/426, the bikes are really, really similar, really really reliable, and really really fun. If it doesn't already have the 03 YZ450 cam mod, do it. It makes a really really good bike great!
  • JamesD
Posted March 01, 2008 - 08:01 PM
I'm pretty sure my WR400F is a 2000 model and the 426 came out the next year.
The 2K model had fixed most of the little problems on the bike so I'd say if you are going to buy a 400 the 2K model would be the best.
  • byggd
Posted March 02, 2008 - 02:18 PM
In a word .... BULLETPROOF!
  • TRUE_2_YAMAHA_001
Posted March 02, 2008 - 08:40 PM
I own a 2001 WR 426 and the only maintenance that i have done other than changing the oil is the spark plug. It has been a stout bike. My uncle has the bike that you are looking at and has had absolutely no problems with it eather. I think that it is a GREAT first bike!
  • TRUE_2_YAMAHA_001
Posted March 02, 2008 - 08:43 PM
Can you tell me about the 03 cam that you put in the bike? I have a WR 426 and i am looking at ways to squeeze more power out of it.
  • byggd
Posted March 03, 2008 - 04:42 AM
Here are the instructions w/the part number.
  • matt4x4
Posted March 03, 2008 - 05:38 AM
I have a 2000 Wr400F as well - ditto to bulletproof, probably the best way to describe this bike. Once you get it, hardest thing is the right starting procedure - once you dial that in, you're golden.
  • wr400schek
Posted March 03, 2008 - 08:57 PM
The Easist Bike To Maintain
  • uniclic
Posted March 21, 2008 - 11:13 AM
Just bought a 1999 wr 400f, great bike on the dirt, runs out of gears too quick on the road. Puts a smile on my face though. I think I better change the oil tomorrow, after reading all the posts about it.
  • Koof
Posted March 21, 2008 - 11:54 AM
I'm also looking at getting a '00 WR400 and was wondering if the problem with the breather tube sucking sand and water affects the 400's as well or is it only the newer 450's??
Thought this might be an appropriate thread to ask this question...
Thanks
  • creeky
Posted March 21, 2008 - 12:14 PM
I got my '00 WR400 from a buddy who bought it new and raced enduros for 4 years. He had problems with the cam chain adjuster at first, but warranty made it good, no problems after that. He had the top end and a valve job done on it just before I bought it. I've been trail riding it for 3 years and have had only a leaky fork seal. I have heard reports that the carb slide can come apart and the pieces sucked into the engine, so an inspection and/or replacement of the slide might be in order just to be safe. As for the breather tube, you can reroute it to a higher location and put a filter on it.
  • storm 800
Posted March 21, 2008 - 05:29 PM
I have the 200 WR 400 an it rock's! Never ever had a problem. I moved the breather tube up behind the headlight with a filter on it, I also did all the free mod's to. This spring I want to do the auto decompress cam. Other than that I just ride. Oh yea I also have the FMF power bome header an Q2 exhaust. Very quiet
