Try again :rolleyes: Grenaded XL650 countershaft
8 replies to this topic
  • Bermudacat
Posted February 29, 2008 - 06:29 PM
My buddies 2003 XL650 grenaded the countershaft under the countersprocket at aprox. 27k miles. It was ridden hard but maintained well.
Is this unusual? How many miles on your XL?
Please do not interperate this thread as an opportunity to buy a used XL as that would be against forum rules. :)
If he decides to sell his bike it will be on Craigslist or the 'For Sale' forum on thumpertalk. :smirk:
Thank you.
  • cleonard
Posted February 29, 2008 - 10:28 PM
Thank you.
What do you mean by "grenaded?" Did the splines strip on the countershaft where the sprocket goes?
If so. it's not all that un heard of. The consensus is that bad sprockets can make it happen faster.
It's not all that hard to replace, but you do have to split the cases. Not good for an unexperienced home bike mechanic. It's a $90 or sh shaft and another $90 or so gasket kit. Beyond that at 27k it likely needs new rings and possibly a piston and it would be good to have the valves looked at.
It's a good opportunity to drop in a high comp piston and a cam. It will be a different bike when done.
  • Bermudacat
Posted March 01, 2008 - 10:07 AM
Yes I did. Sorry for not being clear.
Poor quality replacement? Brand? Installation? It's quite likely that this was the cause.
Interesting assesment of the top-end, thank you.
He's not a bad mechanic, but he's never split a case before. Basically, with work and a family of four, he'd rather not spend a weekend wrenching with other family pressures. Apparently labor is around $1,500 but we didn't know parts cost so thank for that update.
I'll urge him to go the repair route as you've suggested.
Thanks again! :smirk:
Any one able to reccomend a good shop in Western Washington?
  • martinfan30
Posted March 01, 2008 - 12:29 PM
Motosportsman lives up there, try PM'ing him.
  • Denn10
Posted March 01, 2008 - 09:39 PM
i wouldnt be so quick to just throw in the towel like CLEO said, check around and pm MOTO like martin said, maybe you can get some help locally and not have to pay an arm and leg. GL i hope you can get r fixed. theres another in WA ill find his name ive seen him B4
  • Ryanthegreat1
Posted March 01, 2008 - 10:02 PM
I just recently did a bottom up rebuild on my L. Replaced the counter shaft and both sides of third gear while I was in there to fix a poorly done piston install by the previous owner. Not all that hard of a task, just takes some time. Let me know if you need any help.
Oh and any chance you are a member of pnwriders.com?
  • XR250rdr
Posted March 01, 2008 - 10:08 PM
If I was closer I'd offer to do the work at a good rate. I certainly have the time at the moment.
  • Bermudacat
Posted March 02, 2008 - 12:12 PM
That's a generous offer, thanks.
I'm not but I should probably check it out. I find myself with weekdays off quite often.
  • EarlT
Posted March 11, 2008 - 08:25 PM
Replaced countershaft &both sides of third gear
Why did you Replace the Countershaft
& Both sides of Third Gear ?
Is that a Weak point of the XR's?
