oil change problem????
3 replies to this topic
  • brianO1YZ426
Posted February 29, 2008 - 06:05 PM
im changing the oil filter on my 426 and the filter was hard to get out. now i cant get it screwed back in, was it just stuck in there before or does it screw in like a cars?? i know this sounds dumb but id like to be sure before i put the filter cap back on:bonk:
Posted February 29, 2008 - 08:16 PM
It simply sits in the well, and the cap holds it in place. But a not so dumb thing to look at is whether the rubber base pad from the old filter is still on the filter (where it should be) or stuck to the engine case (where it will interfere with the installation of the cover). Take a look.
  • brianO1YZ426
Posted February 29, 2008 - 10:06 PM
Hey thanks man. I checked for the rubber washer and it WAS stuck on the engine case, I took that out and the new one fit a lot better. why would it stick ? was it melting to the case?:smirk:
  • ridinredneck
Posted February 29, 2008 - 10:13 PM
nah. it happens a lot. nothing to worry about. just be sure to check for that every time you change the filter.
  • Hot  30 replies
  • 10 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 0 replies
