600r performance improvements
No replies to this topic
  • Ch47_pilot
Posted February 28, 2008 - 08:04 PM
Here's a rundown of the parts I've recently ordered:
2000 XR600r
Fredette racing chain guide
Moose shark fin
Acerbis DHH dual 35w halogen light kit
Ricky Stator 200w stator and heavy duty AC regulator
Meier MX style rear fender
Baja designs LED brake/tail light (under fender kit)
Magnetic oil drain plug-frame and engine
FMF pipe with powercore 4 exhaust
Trailtech Vapor
Works Connection frame guards
SRC front fork brace and mudskins fork saver
XR's only case saver
Mikuni flatside 41mm
Uni filter
Current mods:
oil cooler mod (from 450)
Xr's only oil temp dipstick (so far a great investment)
Scott steering stabilizer
Stainless oil filter
race tech gold valve (rear)
stock header with weld ground and ceramic wrap
Big Gun quiet exhaust
K&N filter/ airbox mod
I ride about 75% road, 25% dirt average, but that changes quickly, depending on my spare time, and if a new trail gets discovered (kinda sparse out here.) I plan to run the 200w stator full AC. Supposedly it will run everything fine as long as I'm using the High wattage regulator. Stock light/stator is way too dim to even run on the street at night. I think the carb will work great with the exhaust. Originally wanted White bros E2, but they are long gone. I was debating on a Hotcams stage 1, but I am 165 lbs as it is, and this bike pulls low end throttle wheelies in 1 and 2 with no regard to where my weight is on the bike. I predict the mikuni's snappy low-throttle response will intensify that ten fold. Seems plenty of power as it is, my only ever bitch was the lack of throttle response with that stock carb.
Any good opinions, tips or install advice? I pretty much went off of what I found in here from reading what you people have said / recommended in deciding on my purchases. By the way, thanks for that. Pics to come.
  • 22 replies
  • 17 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 3 replies
  • Hot  29 replies
