sunline fuel screw
7 replies to this topic
  • Slinkyman16
Posted February 27, 2008 - 03:01 PM
any tips on installing this.. ive already read the tips given to the guy who bought the white bros screw.. anything i should look out for after installing this? the kit came with two o-rings, a small washer and a spring.. what is the correct way to install this.. meaning install precedure what goes in first..
  • William1
Posted February 27, 2008 - 03:20 PM
screw-spring-washer-Oring then slip up into the opening
Same as the stockersecond
Second Oring can be a spare or put on the screw shaft to provide additonal friction to keep the scew from loosening and falling out.
  • Slinkyman16
Posted February 28, 2008 - 03:02 PM
thanks.. now does anyone know how many turns out it needs to be for around 3-4k feet. stock jetting. thanks currently i have it at 1.25 turns out.
  • William1
Posted February 28, 2008 - 03:49 PM
Starting point is typically about two turns. There is a sticky in the jetting forum that will walk you though setting it correctly.
  • Slinkyman16
Posted February 28, 2008 - 04:10 PM
i loked threw the jetting sticky.. but didnt find much except other peoples stuff.. but ill look again..
  • Slinkyman16
Posted February 28, 2008 - 04:16 PM
just went threw the jetting tips/suggestions and nothing.. bike i stock. stock jetting and running around 3-4k feet.
Posted February 28, 2008 - 04:22 PM
What he said was:
... not in the jetting sticky here.
Might also look at this:
http://www.thumperfa.../jetting.htm#PJ
  • Slinkyman16
Posted February 28, 2008 - 04:27 PM
thanks grey... ill go do that right now..
  • 5 replies
  • Hot  28 replies
  • Hot  36 replies
  • Hot  47 replies
