Water leaking from water pump
2 replies to this topic
  • presite
Posted October 29, 2002 - 02:09 AM
When I start my bike from cold water drips out from the water pump vent hole in the casting. This water stops after 1 or 2 mins. and does not leak again until the next time.
  • Thumpster
Posted October 29, 2002 - 03:54 AM
Hmmmmm, sounds like the outer seal is going. The seal is inexpensive and only takes 30 minutes to replace (if that).
Pull the water pump cover off, remove the impellar, gently pry out the old seal. Install new seal and gently seat it to the back of the housing. Reassemble and torque the cover bolts to spec. I had the same problem on my old YZ.
Good luck.
  • banffboy
Posted October 29, 2002 - 05:35 AM
You will probably want to do the impellar shaft seal at the same time
