Rear tire
17 replies to this topic
  • Jetmoto120
Posted February 25, 2008 - 09:17 AM
Will this tire fit my pig?
Michelin Baja Tire 140/80-18 :smirk: thank you
  • martinfan30
Posted February 25, 2008 - 09:27 AM
It fits an L. I'd be shocked if it wouldnt on an R.
  • sj269
Posted February 25, 2008 - 03:01 PM
yes, but run it as far rear in the swingarm as your chain will allow, it will eat/rub on your mud flap thingy otherwise. Oh yea it was a beech to mount.
  • Jetmoto120
Posted February 26, 2008 - 01:18 PM
Thank you I will try one out
  • husky123
Posted February 26, 2008 - 03:52 PM
It will definitely fit!
  • martinfan30
Posted March 19, 2008 - 08:01 PM
Yes they fit well...
Posted Image;
Posted Image;
Posted Image;
Posted Image;
Posted Image;
  • ghrati ghoti
Posted March 20, 2008 - 05:17 AM
I really hated the way a 140/80 handled on the street. Turn in took a lot more effort. One thing to note on the bigger rear is the change in gearing, it will be similar to dropping 3 teeth on the rear sprocket.
  • martinfan30
Posted March 20, 2008 - 08:01 AM
Wow. I knew it would lower the final ratio a little over the 130/90... That much though?
With my current 15/48, I guess I wont need to get a new 14 CS sprocket.
  • ghrati ghoti
Posted March 20, 2008 - 09:40 AM
I think I calculated it at 2. something. The 130/90 is taller than a 140/80, making it closer to 3 teeth. In other words, if you have a 130/90 and 15/48, you should be darn close to the stock ratio, (15/45 and 4.60/18).
  • martinfan30
Posted March 20, 2008 - 10:06 AM
I was just shocked that the 80 vs 90 would make that much difference.
So with 15/48, it'll feel like 14/48.
  • ghrati ghoti
Posted March 20, 2008 - 10:55 AM
I don't think I'm explaining it well.
Stock = 15/45 and a 4.60/18 tire.
this would be very close to
15/48 with a 130/90 or 140/80 tire.
My figures were based on the stock tire height of 85% or 3.91"
a 130/90 is 5.12" wide x 4.61" tall.
a 140/80 is 5.51" wide x 4.41" tall.
The taller rear tire makes the sprocket appear smaller to the final ratio.
  • martinfan30
Posted March 20, 2008 - 11:02 AM
Yes, I understand a taller rear tire will make the final ratio taller.
I just wasnt sure how much difference there would be between the 130 and 140 only... Final ratio wise.
Thanks for your advise!
Funny thing about written communication.... Sketchy at best!
  • ghrati ghoti
Posted March 20, 2008 - 11:20 AM
It's okay I'm used to it, my wife doesn't understand me either. :confused:
  • martinfan30
Posted March 20, 2008 - 11:58 AM
It's okay I'm used to it, my wife doesn't understand me either. :excuseme:
You either?:confused:
  • cleonard
Posted March 20, 2008 - 12:28 PM
Before I begin, let me put on my asbestos shorts... OK now I'm ready
When trying to find that actual installed size the numbers on the tire don't always give you an exact size. The best thing is to use the mfgs data. Most list installed width and diameter. However, some like Michelin do not. It can vary a lot by manufacturer.
Most mfgs also list a rim size. My guess is that most would not recommend a 140 width on a 2.15 rim. Just because it looks cool doesn't mean it will work better. In deep sand or mud, yes the wider tire will generally help. On the pavement a wider tire may actually result in a smaller contact patch on the ground. An oversize tire will usually wear faster since only the very center of the tire ever contacts the ground.
  • martinfan30
Posted March 20, 2008 - 12:34 PM
Is the rear rim 2.15?
I realized that street use would kill it quicker than the 130 or 120, I just wanted to see how it compared to the 130. Which I loved.
  • ghrati ghoti
Posted March 20, 2008 - 01:11 PM
And some manufacturers measure width at the sidewall, others at the knobs.
  • Jetmoto120
Posted March 21, 2008 - 05:20 PM
Thanks for all the info i have two wheels so one will be 120/100 and one 140/80 i found a problem my adjuster bolts are rusted into the swingarm and will not turn any ideas? sorry i dont know the proper name
  • Hot  35 replies
  • 4 replies
  • Hot  29 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 3 replies
