the carb overflow on my yz450f
5 replies to this topic
  • asxasxz
Posted February 24, 2008 - 08:46 PM
keeps pumpin out gas when i put gas in it and i allready checked the floats and thay arnt stuck so what could be wrong please help me :smirk:
  • ProjectDIRT
Posted February 24, 2008 - 10:16 PM
is the little cylinder that the floats control stuck? sometimes it gets clogged up.
Posted February 24, 2008 - 10:45 PM
That would be the needle valve. It has to be able to hold fuel out of the carb with only light pressure. If it gets even a tiny piece of dirt on it, it won't seal. It can also be worn out, or if it was used for a while then sat for a while, it may have dried out and cracked.
  • asxasxz
Posted February 25, 2008 - 09:59 AM
can i buy a new needle valve
Posted February 25, 2008 - 10:03 AM
Yes you can.
  • todds924
Posted February 25, 2008 - 02:10 PM
alot of times if the bike sits for awhile they will get stuck...you might try tapping lightly on the side of the float bowl and see if it stops leaking.
