kickstarting '06 wr450
19 replies to this topic
  • simonreeves
Posted February 24, 2008 - 05:48 AM
hope this is'nt a dumb question, & i have searched, but all the references to kickstarting seem to refer to older (i think) models with a manual decompression. These models seem straightforward enough but on my '06 i think it has an auto decompressor, so is there a procedure for kicking it? I normally use the electric start but on cold starts it sometimes struggles, especially if it hasn't been started for a few days. I usually kick it 'till i'm blue in the face, then give up & have to rely on the electric. ( i am using the choke & bike runs fine once started) Thanks for any info.
  • 2grimjim
Posted February 24, 2008 - 09:37 AM
Kick it just like a 2-stroke but DON'T EVER open the throttle while trying to start it (even with the electric starter).
  • h20mn
Posted February 24, 2008 - 09:59 AM
I have an 06 and when I kick start mine just for the hell of it. I open the throttle slowley half turn and then release it. always starts in maybe two or three kicks at the most. hope this help
  • simonreeves
Posted February 24, 2008 - 10:27 AM
thanks for the replies guys, seems there's no great secret to it then, i'll just have to get a little fitter and try a little harder, quick twist on the gas and then just keep kicking (and don't touch throttle again) ! thanks.:smirk:
  • Justang
Posted February 24, 2008 - 10:34 AM
My 05 kicks over in 1-2 kicks when cold. Most of the time it's one kick. The e-start does struggle when cold.
  • w00dsRider
Posted February 25, 2008 - 04:02 AM
I have an 06 it has auto-decompress and I to have to resort to the kick starter on cold mornings as well.
My routine:
Open petcock, turn the bike on, pull choke, crack the throttle open all the way three times at moderate speed, use the happy button without touching the throttle, for a few cranks if no joy crack the throttle open one or two more times and kick start. Rinse repeat as necessary.
I must admit that I do 'touch' the throttle a very little bit once in awhile but I have my idle set pretty low.
  • Justang
Posted February 25, 2008 - 08:31 AM
Yeah, I to touch the throttle at times. 99% of the time I don't need too.
The 05's have auto decompress too. So much nicer than that manual decompress and sequence of starting we used to have to go through.
  • texas_hippie
Posted February 25, 2008 - 06:39 PM
Yep, that works for me!
  • brad the best
Posted February 25, 2008 - 10:10 PM
personally if my bike is cold even if i flip the throttle i will kick it for 5 minutes or e-start for 20 seconds . however if i start off at tdc each time with the kick start it will start in about 10 kicks . i mean like -10 with out re-jetting and 10-30
so personally i always put it to TDC when i kick it and it usually fires fist kick in the summer .
  • ww44wrf450f
Posted March 05, 2008 - 09:17 PM
if your having broblems starting may I suggest cleaning out the carb n jets is usually a good place to start? after cleaning mine it help 100%?
  • Face plant
Posted March 06, 2008 - 12:32 AM
[quote name='w00dsRider']I have an 06 it has auto-decompress and I to have to resort to the kick starter on cold mornings as well.
My routine:
Spot on.:eek:
Works every time with mine, even if it's been sitting for 2 weeks ( which sadly does happen sometimes:thumbsdn: ) it still works just like that.:thumbsup:
  • wr_matt
Posted March 06, 2008 - 12:45 AM
The '07 is pretty similar.
Twist the throttle 2-3 times, open the choke and kick it over once or twice. Fires right up :thumbsup:
  • Eddie5150
Posted March 06, 2008 - 09:51 AM
Same thing with my '06.
eddie
  • ajetmech
Posted March 06, 2008 - 10:13 AM
My 06 goes in 1-2 kick's. I had problems a few months back check the valves and re-shimmed the exhust side and no problems. If you got to kick that many times might be a good idea to check valve clearance. Did it myself as per the manual only took about 1 1/2 hours including a trip to buy shims. 7 bucks each. total cost was around 20 bucks including 2 shims, new gasket and a set of feeler gauges. Local bike shops want 150 to 200 plus 15 per shim. dont understand that part when they sell them outright at 7 each.
  • 123BigcoopDawg576
Posted March 06, 2008 - 10:16 AM
i would agree....its all a rip off
  • jcorni
Posted March 06, 2008 - 10:24 AM
What is a kick start lever :thumbsup:
  • dugabrams
Posted March 06, 2008 - 10:49 AM
More specifically the pilot jet, unless your '06 is a mess. If your jetting is good(ie pilot and maybe your starter jet) it should start very easily when kicked.
I had a similar but rare problem, turned out I wansn't getting good spark at low rpm due to a broken stator. Check your spark the old fasion way to eliminate any chance of electrical problems, and then move onto the jetting.
  • simonreeves
Posted March 06, 2008 - 12:24 PM
thanks for the many replies guys, i must admit i've got kind of used to the easy button and haven't even looked at the kickstart lately. I'll put some of this advise into practice next chance i get ! Cheers.:thumbsup:
  • simonreeves
Posted March 15, 2008 - 10:33 AM
i know it's not the worlds greatest achievement but it made me happy, haven't started her for 2 weeks so i thought it would be a good time to try the 'old-fashioned' method. fuel on, choke on, ignition on, 3 slow full twists of the throttle and kicked it good and solid, took 4 or 5 kicks but that was probably just my slightly rusty techniqe ! Thanks for all the input guys, now the worlds my oyster ! Sorry, getting carried away with my success.:confused:
  • simonreeves
Posted March 15, 2008 - 10:41 AM
thanks Woodsrider, your routine seems good for me
