wr450f-07 stock springs
7 replies to this topic
  • henrics
Posted February 23, 2008 - 04:04 AM
Hello wr owners!
Im about to buy a wr450f-07, coming from a yz250f-06..
If i look in manual it says
fork:0,459 kg/mm, shock 5,5 kg/mm
Race tech says
fork:0,460 kg/mm, shock 5,3 kg/mm
Mx-tech says
Eibach says
fork:0,470 kg/mm, shock 5,0 kg/mm
who is right?
A do recall someone measured the stock spring but can not find the post..
What springs would be right for me 90kg (200lb) without gear.
Fork and shock is stock -not revalved.
thanks Henric
  • tweav
Posted February 23, 2008 - 04:29 AM
I could never get a straight answer on this ether . I also weigh 200 and have a 07 wr450f . I put on the stock rear spring from a 06 Yz 450f because I got them cheap and it feels better . but just it is still bit soft. but not bad in the woods . just no big jumps abit too soft of that , but that is not what this bike is for anyway.
  • clark4131
Posted February 23, 2008 - 07:17 AM
Forks=.48 Springs
Shock=5.8 Spring
  • henrics
Posted February 23, 2008 - 08:18 AM
Thanks!
I`ve talked to 5 diffrent susp guys in Sweden and they all suggest diffrent springs for my 90 kg.
Mansson :0,47+5,7 http://www.motostar.se/fjadring.htm
Kumlins :0,48+5,8 http://www.factoryconnection.org/
Springzz: 0,46+5,5 http://www.springzz.com
Eklof suspension: 0,44/0,45+5,6 http://www.eklof-suspension.com/
Meijer suspension 0,469+5,5 http://www.mmtech.se (race-tech stuff)
I`ll try stock spring then try to figure out witch way to go:ride:
  • clark4131
Posted February 23, 2008 - 09:57 AM
Springs tend to run in even numbers and you should go up to the next highest if you hit a recommendation that gives you an odd figure, hence .48 and 5.8...SC
  • Demo_Slug
Posted February 23, 2008 - 11:34 AM
will different valving affect the recomended spring rate?
ie, more compression damping + lighter spring
  • clark4131
Posted February 23, 2008 - 03:15 PM
It can, that is why RaceTech's recommendations are notoriously light. They factor in adding their valving...SC
  • henrics
Posted February 24, 2008 - 04:17 AM
Does by the way the springs from a wr450f-07 fits in a yz250f-06 fork?
