led turn signals
9 replies to this topic
  • xr650l bum
Posted February 22, 2008 - 06:07 PM
I hooked up some rear led turn signals today. 12 led lights with 2ohm 25w resistors in parallel. They blink nice and all, but they are not very bright. Is this the way they are? I may just go to filament bulb, but aftermarket. What a waste of money!
  • martinfan30
Posted February 22, 2008 - 09:29 PM
I think this is why alot of the A/M LED lights are not DOT. THey just dont light it up during daylight.
  • dmvmechanics
Posted February 22, 2008 - 09:32 PM
how fast do they blink? if they blink real fast you may have too big of resistors
  • martinfan30
Posted February 22, 2008 - 09:38 PM
I think he has a good "blink rate". Just not happy with the LED being bright enough.
Although you are right, too much resistance will make the flasher act faster...
  • CTXr650L
Posted February 23, 2008 - 03:50 AM
i'd ditch the resistors and get an electronic flasher instead. most auto parts stores have em. the resistors might be giving you a little bit of a dimming effect.
  • xr650l bum
Posted February 23, 2008 - 05:30 AM
I kept the stock turn signals up front. They really dont bother me, dont break or really even burn out. The rear system needed to be changed(no tv set). I used a smaller resistor than what was shown to me. Moto store wanted to sell me some ?ohm 50w resistor. That seemed to big. The blink rate is right on. I went with amber color lens, trying to keep it as DOT as possible. I believe that this is why most makers dont use the amber lens, but clear lens with colored bulbs. I will try some clear lenses with amber bulbs before I shite can the idea.
  • Blacksamwell
Posted February 23, 2008 - 05:53 AM
I'm curious to see if you can get the intensity you're looking for by changing out the resistor.
I've got some LED brake/turn lights on my trailer and they are almost too bright.
  • xr650l bum
Posted February 23, 2008 - 04:14 PM
I tried to put a smaller resistor in, but it was not enough. The 2 ohm 25w resistor is the right size for the flasher unit. I changed to an 15 amber led light with a clear lense. This is brighter, but does not impress.
  • porterdog
Posted February 25, 2008 - 09:03 AM
There are HUGE differences in LED quality/output. Try www.superbrightleds.com for some ideas- I got my turns from there and am relatively happy with them. (Always remembering that a) I'm invisible when on a motorcycle, and :smirk: every other driver wants to kill me.)
  • xr650l bum
Posted February 25, 2008 - 09:12 AM
I totally agree Pdog. I am over the led craze. I purchased several of the latest and greatest to try. The unit I made for the rear turned out nice. I have learned some things in the process. If you want to stay DOT you cant change a hole lot. This is why I left the front blinkers on, so the law could not say I was in total violation. If using led blinkers with resistors, you are not saving any energy. The led may last longer, but that I have not proven yet. With the brake/ tail light, you just cant beat the dual filament bulb.
